Question about Dell OptiPlex GX520 PC Desktop
Have a dell optiplex gx520. Little cousins broke the plastic part of the USB port in the front panel. So I disconnected the the front panel connector and then the computer turned on. It was turned off about an hour later and now I cant seem to turn it back on. I dont hear the fans or anything. Please help. Thanks.
  • Dell Master
  • 4,924 Answers
Take a good look inside cause when you removed the front usb you probably removed the front panel buttons too ..Plug them back and will work ..
The fact that it worked is probably why you never seen it ..It does not need the button to be connected in order to work ..the start only kicks it on ..
If this button is damaged ..you can go to bios and look if it has other alternatives fro starting ..(select to start on a set time ..or look if it is capable to start from the keyboard or on mouse double click ..some computers have this option ..for dell i think only to start on a certain hour it is available ..but if you damaged the front button is still an option ..you can also make it sensitive on the ac power ..and if the button is damaged it will start when you plug it in the inlet ..
You may actually try this ..cause unless you plug the button back ..you will not have a way to start it ..so ..try to see if it is set to react on power ..just remove it from the back and place it back ...if you are lucky will start just like it restarts when there is a power fluctuation ..
if not..you need either to reconnect the front panel ..or look on the manual ..and see teh exact pins for the start button ..and short them with a jumper untill it starts ..and make changes in bios ..and use teh keyboard or the mouse or the alarm start until you replace the button or the case...
Posted on Dec 27, 2011
2 Suggested Answers
leethedeuce
  • 4472 Answers
SOURCE: Have a dell optiplex gx520.
Hi, Have you tried plugging in what you have unplugged? Try turning it on with the case open and see what is going on. You may need to take out the bios battery out and then turn it on, then turn it off and re plug in the bios battery. How long did it work after having the usb port in the front broke?
Once I have more information I can assist you further.
Thank you,
Lee
Posted on Jan 04, 2011
Dell OptiPlex GX520 PC Desktop won't power on
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jan 31, 2014 | Dell OptiPlex GX520 PC Desktop
Dell Optiplex gX520 will not boot beyond the splash screen. Dell Optiplex gX520 will not boot beyond the splash screen. There are not post code beeps.The lights on the front panel are 1 and 4. Both are...
Sounds like you may have multiple problems. Suggest trying to eliminate possible causes by removing components. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Remove the components one at a time and see if the LED's change.
Dec 10, 2011 | Dell Optiplex GX520 Desktop PC - Intel...
Yellow light on the power button of my Dell Optiplex GX520. I've tried: 1. Replaceing the power supply 2. Replacing the CMOS battery 3. Removing and reinstalling the RAM memory. 4. Replacing the...
A solid orblinking Amber power button indicates a voltage problem. This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Sep 18, 2011 | Dell OptiPlex GX520 PC Desktop
I have a Dell Optiplex GX520 m/c, when we switch it on, it's on/off switch light keeps blinking in Orange mode.
blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
May 09, 2011 | Dell OptiPlex GX520 PC Desktop
I need an audio device for my dell desktop optiplex gx520 install
if u cant install the sound driver just buy a USB sound adaptor and connect it to the USB port and connect the speaker sound jack to the sound port in that....u will have sound....also keep in mind that u " may" have to disable onboard sound in BIOS
get it in Ebay or goole it to locate a place near u
Feb 24, 2010 | Dell OptiPlex GX520 PC Desktop
Broken USB jack, no power.
1) Unplug the computer from power. Open the computer case.
2) TOUCH the metal frame of the computer case. (Not shouting)
This will relieve your body of Static electricity.
3) Unplug the front panel USB cable from the motherboard. (If there are two cables coming from the front panel, unplug them both)
4) Close the computer case.
Press the Power On button in, and hold it in for a count of Five seconds. Let go of the button.
Do this procedure two more times. (Total of three times)
What you are doing is clearing any CMOS Error Codes, and setting BIOS Setup back to the factory default settings.
5) Plug the computer back into power. WAIT 1 minute. Turn the computer on.
If the computer still doesn't start, the motherboard is fried.
(I believe the computer will work okay)
There is no Service Manual available. If you follow the cable/s from the front panel to the motherboard, you'll see where it/they connect.
Jan 17, 2010 | Dell OptiPlex GX520 PC Desktop
Dell optiplex gx520 keyboard
its not the on your USB connection, your keyboard is malfunction... buy a new one or keyboard
Jun 17, 2009 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
