Question about Nokia 3120 Cellular Phone
Battery drain fast
Got a problem with my 3120.the battery seem to fun low very fast. i had change the battery to a new one. n still the same.is there a problem with the set itself? plz help me.
  • wildshay Jul 09, 2008
    nope. the phone dont have bluetooth. this is the old nokia 3120 look alike 3100. thanks
Nope.the phone dont have bluetooth. this is the old nokia 3120 look alike 3100.
Posted on Jul 09, 2008
    Sergeant:
  • 287 Answers
Do you have bluetooth enabled? If you do and you are not using it to connect to a headset or other device, it will drain the battery quicker
Posted on Jul 08, 2008
My mobile battery is getting low very fast
It's probably old, and about time to change the battery. If not, could be some function that drains battery fast, eg. high accuracy location tracking. Set to battery saving option instead.
Feb 07, 2015 | Cell Phones
Battery problem for experia arc s
Batteries do not last forever, they often need to be changed, Looking at the specs of this phone the battery MaH is pretty low for the type of phone that it is. Android phones can drain batteries quite fast, and depending on how long you've owned the phone.
You can purchase a replacement battery, or.. An Extended battery can help keep your phone running for longer periods of time. (http://www.amazon.com/ericsson-Replacement-Lithium-Ion-Extended-Battery/dp/B005PFOGIW)
Sep 03, 2012 | Sony Ericsson Xperia Arc S
Battery power just seems to drain away very quickly
Please check the voltage on the terminals of the battery in the phone. If the voltage is good then check the voltage on the battery, if low the battery is faulty as it may not be retaining the required current factor. Best way to confirm is to swap with one of your friend's phone.
If adapter voltage output is low , try and check with another adapter before it can be changed.
Mar 03, 2011 | Cell Phones
Kenmore washer top load all cycles normal but when in the rinse/spin cycle notice it does not seem to spin fast enough to remove water from clothes and the are wetter then normal
There could be a number of reasons My best guess is that it will reduce the spin speed if it thinks it can't drain properly. Check that all the pipes/ filters etc are clear and that it can drain all the water out. Also it wont spin fast if the load is unbalanced. Does the spin speed change according to loading or is it low all the time? It may have a motor control problem, but that seems unlikely if it's working normally other than the spin.
Jan 13, 2011 | Washing Machines
Frigidaire glws1233as1 water runs continually. seems like a valve is stuck open or something. water is draining as fast as it is filling up.
your drain hose or drain is too low causing water to siphon from the tub as fast as it runs in. raise or loop the drain hose higher than the highest level of the tub.
May 28, 2010 | Washing Machines
Actually my mobile battery is draining very fast even i am not using my mobile just except accepting the calls on my phone Even im closing all the applications properly im fully charging my mobile it shows...
Does the phone usually gets hot before the battery runs down?
Try changing the battery, maybe the battery cell is weak.
Let me know what happens after changing the battery, so that I might direct you further.
Take care.
Nov 20, 2009 | Sony Ericsson W700i Cellular Phone
Battery dies really fast
change power setting or get a new battery
May 29, 2009 | LG Vu CU920 Cellular Phone
Nokia 3120 Cellular Phone Logo
148 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
