Question about Dell XPS 200 PC Desktop
There is definitely a power supply problem with the Dell XPS 200 I have. It starts fine and runs beautifully for about an hour. Then suddenly the screen goes blank, the light on the power button flashes yellow, and the back of the chassis is hot. This would appear to be a heat buildup problem, indicating that the fan is not powerful enough to dissipate the heat, would it not? The fan is not noisy on this CPU. The design of the chassis is very small; is it too cramped to permit the heat buildup to escape? Increasing the wattage of the power supply would only make the heat buildup problem worse; you would need a more powerful fan, would you not? If so, does Dell have a replacement for the power supply on this model that has a better fan? Do you know the answer to these questions? Thanx, Molly
  • 71 Answers
Molly
The first thing, take the cover off and blow out the dust with caned air. NEVER vac near electronics! After you get it cleaned out, (the power supply to) make sure the fan on the power supply is working. If all the fans are working you should not have any more trouble. Keeping your computer dust and dirt free is the basics of trouble free electronics.
PS. make sure the vents on the covers are clean and unobstructed.
Posted on Dec 31, 2010
  • 591 Answers
First ingeneers build things to fuction AS IS, so i'm not sure you need more fan power.
Verify the inside of the computer is the CPU heat sink (big aluminium block with fan) CLEAN of any dust? are all the fans turning correctly (resonable speed)? verify the placement of the PC itself is it cooked up in a cabinet or pushed against a wall (blocking the holes in the case for air intake)?
if all of the above is OK you could re-paste the CPU (spreading new heat sink compound between the CPU and the heat sink)
Dell VOSTRO 460 beeps during startup and will not startup.
many times if the fan over the cpu chip on the motherboard fails to run or blow, an beeping alarm will begin and PC will not start. the cpu has to be kept cool so if fan fails the startup is stopped. have found lose wire connections from fan to motherboard terminal, or power supply may be blown, try checking those first. if nothing lose then wiggle those wires to see if the fan starts.
Jan 30, 2014 | Dell XPS 200 PC Desktop
Have an xps 200, monitor suddenly went black the other day in the middle of use. Noticed the power light had gone from green to amber. When I push button on monitor says it is in power save mode, to move...
Try connecting the monitor to a friend's computer. If you get some sort of a display it's not the problem. When you say that the computer makes a new noise like the fans are spinning fast, you might have an issue with the video card , motherboard, or power supply.
Aug 05, 2013 | Dell XPS 200 PC Desktop
My Dell XPS 200 will not turn on.
Have you checked to see if your power supply is still good, or the power supply connection to the motherboard is good?
Sep 14, 2012 | Dell XPS 200 PC Desktop
My dell xps 200 shuts down and the power light flashes amber. I try turning it back on and it does not respond. I have to unplug it from the outlet wait a few seconds then plug it back in. After I do this...
You can try unplugging the PC, removing the RAM and re-seating it. It could also be a power supply issue, either too much for it to handle or it's not functioning correctly. My first suggestion would be unplugging hardware that's not needed for a week or so and see if it keeps happening with only the HDD plugged in. If it doesn't continue plug one thing in at a time until you find the culprit... although because it does run for a bit when you have the so called culprit, unplug it and plug something in its place, if it continues then you may have over powered your power supply and need to get something a bit larger.
You may also have issues with the PC over heating or fans not running correctly, make sure to check these items while your PC is turned on. (please be careful).
Mar 07, 2011 | Dell XPS 200 PC Desktop
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
Dell XPS 200 Computer shuts off leaving blinking amber light
3 most common solutions to your problem are:
  1. Bad power supply; once it heats up will quit without warning
  2. Bad heatsink/fan; processor heats up and will lock up your Pc
  3. Bad motherboard
Try opening the machine and give the inside a thorough cleaning, paying special attention to the heatsink and fan. Once clean and you've ensured the fan is operating, put it back together and see if your problem is fixed. If not, a new power supply will likely fix your problem. Best of luck.
Greg
Jul 06, 2009 | Computers & Internet
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
Why does my computer suddenly shut down during use?
remove the side panel and have a look if your cpu fan is turning.... you may need to blow the dust and dirt out of it as well... if the tower even feels remotely warm that's likely the issue... also check the fan on the power supply. either way it will likely need to be cleaned
Robert
Jan 13, 2009 | Computers & Internet
DELL XPS M140
One of three things, 1- power supply, check your power supply with an ohm meter to see f it's getting the proper output to the machine. If the supply is starving the machine of power the charging system won't work to it's full potential. 2- the power management system on the motherboard, if this system isn't working properly it can divert power from the charging system. If it's just glitched then a bios download or chipset utility download will fix it, if it's malfunctioning, then motherboard replacement is the only option. 3- the battery itself, I have a Dell, and in the past two years, I've ordered two new batteries. The first held a great charge, more than three hours, but only lasted about eight months. The second only holds little more than an hour charge, but has lasted well. Batteries are just funny that way. Start with the power supply test.
Aug 23, 2008 | Dell Inspiron XPS M140 Notebook
Dell XPS 200 PC Desktop Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
