Question about Tappan Kitchen Ranges
My Tappan OTR microwave, model TMV151FB, runs but does not heat anything.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Here is a small list, of things that could be wrong with your unit
  • Bad interlocks switches or door misalignment causing fuses to blow or no operation when the start button is pressed. Locate and replace defective switches and/or realign door.
  • Arcing in oven chamber: clean oven chamber and waveguide thoroughly. Replace carbonized or damaged waveguide cover. Smooth rough metal edges. Touch up the interior paint.
  • Blown fuse due to power surge or old age: Replace fuse. On rare occasions, the main fuse may even be intermittent causing very strange symptoms.
  • An MOV, probably on the controller, may have shorted due to a power surge blowing the controller fuse. Remove remains of MOV, replace fuse and test, replace MOV for future surge protection.
  • Erratic touchpad operation due to spill - let touchpad dry out for a week.
  • Bugs in the works - the controller circuit board is a nice warm safe cozy place to raise a family.....
Careless troubleshooting of a microwave oven can result in death or worse. Experienced technicians have met their maker as a result of a momentary lapse of judgement while testing an oven with the cover removed. Microwave ovens are without a doubt, the most deadly type of consumer electronic equipment in wide spread use.
The power supplies for even the smallest microwave ovens operate at extremely lethal voltage and current levels. Do not attempt to troubleshoot, repair, or modify such equipment without understanding and following ALL of the relevant safety guidelines for high voltage and/or line connected electrical and electronic systems.
I will not be responsible for damage to equipment, your ego, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury or worse that may result from the use of this material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
My TMV151FB beeper stopped working. Is it worthwhile fixing it?
if ever thing else works but the beeper I would not worry about that
May 24, 2015 | Tappan Microwave Ovens
Spontaneously stops working and then comes on after 5 minutes. Why?
Sounds like the magnetron is overheating. There is an automatically-resetable thermal circuit breaker attached to the magnetron. Most likely your problem is caused by either a cooling fan that is not running, or is running too slow (caused by gummed-up bearings). In some over-the-range (OTR) microwave ovens, the exhaust fan is run at a slow speed to cool the magnetron, and if it's bearings get gummed up, it won't run on the slow speed. But if it's a new OTR microwave, then the exhaust fan may be pointing the wrong way. (It is rotatable, depending on the installation). For example, if it is pointing up, but you don't have an exhaust vent over the microwave, then the air has nowhere to go, and the magnetron will overheat.
Oct 16, 2014 | Microwave Ovens
Tappan tmv151fb
Chances are you have a failing bottom door switch, or its mount is loose, misaligned, or broken.
See my help file on door switches: http://031d26d.namesecurehost.com/mwd/doorsw.txt
The service manuals are here:
http://www.microwavedisplay.com/tmv151_sm.pd f
http://www.microwavedisplay.com/tmv151f_parts.pdf
You can usually order Tappan parts from the Pros here or contact them via the info no the service manual cover.
Jan 15, 2014 | Microwave Ovens
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Electrolux otr microwave drawing air fromtop of microwave
I would direct you to first refer to your installation instructions to be sure everything is installed correctly.
Then I would refer you to the owner's manual for information on checking and cleaning / changing the grease filter or charcoal filter.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you need further help, you can contact Electrolux at 800-944-9044.
Sep 05, 2012 | Tappan TMT104E1 Microwave Oven
Caracell keeps turning and does not heat
There three common causes, open magnetron, cracked high voltage diode developes high resistance short, or a shorted high voltage capacitor.
Mar 27, 2012 | Microwave Ovens
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
I have a Tappon Microwave model FMV151F. The screen reads -SE-. It will not do anything. What does this mean.
Our 17 year old Tappan Microwave Model # 564878 quit heating. Everything else works. Hard reset did not remedy the problem. Any suggestions?
Jul 13, 2008 | Tappan Microwave Ovens
Kitchen Ranges Logo
405 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
