Question about KitchenAid K45SS Classic Stand Mixer
Bowl is stuck in stand - can't get it out. It won't turn clockwise or counter clockwise.
    President:
  • 1,102 Answers
I know they have to turn COUNTER CLOCKWISE to come off the base. Sounds like "magilla the gorilla" put it on the base. Just keep at it. You might try putting some ICE in the bowl to "shrink" the bowl.
Posted on Dec 31, 2010
Testimonial: "The ice was a great idea. After 10 minutes with ice water in it I was able to turn it and get the bowl off. THANK YOU!"
The stand mixer cant be used for more than four mn
Posted on Nov 24, 2012
Get the bowl to release from the stand
The only way to unstick it is with more energy. Get someone to hold the motor unit firmly and someone else turn the bowl anti clockwise. There is no magic if it's stuck, just more effort required.
Feb 20, 2015 | KitchenAid K45SS Classic Stand Mixer
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
Mar 16, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
The bowl fits too close to the mixing blade and has scraped some of the surface from the blade. I can not find the book
VLCMM: You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of yourOwners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC. You’llneed to have Adobe Reader to be able to open it. Turn to Page 11 and you will find theinstructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Make adjustment with flat beater, so it just clears surface ofbowl.
If you over adjust the screw, the bowl lock lever may not lockinto place.
Bowl-Lift models
• Unplug mixer.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flatbeater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface ofbowl.
If this solution has helped you, please rate it, thanks!. hslincoln
Nov 25, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen aid stand up mixer
You give it a counter clockwise twist about 1/8 to 1/4 of a turn or so and the bowl pops off.
If you need more assistance, post a comment.
Thanks,
Tim
May 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Lowering the beaters on the professional kitchenaid
Hi. With the bowl-lift in the down position, look for a screw on the front of the column. Turn this screw counter-clockwise. This screw will only turn 90 degrees so don't force it any farther. Use the flat beatet to check the clearance. The beater should just clear the bottom of the bowl.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 01, 2009 | KitchenAid KP2671 Professional 6 Series...
Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Jan 12, 2009 | KitchenAid K45SS Classic Stand Mixer
Bistro Staned Mixer;Mixing bowl is stuck(?) to base
You have to twist the bowl anti-clockwise to release it from the base. Twist clockwise to lock it when using the beaters.
Nov 23, 2008 | Wolfgang Puck Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
556 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
