Question about Bose Wave Radio
Clock keeps time but radio will not play. I have tried almost everything to get it started but nothing helps. Please give me help. Judy Steed
    President:
  • 1,654 Answers
Try these tips for the Bose and let me kow if you need furthur assistance.
  • The system is malfunctioning.
    Start by checking the power adapter. Unplug and reinsert the plug from the radio and wall. Make sure both seat correctly in their respective sockets. If the main screen does not display any information while turned on, check to verify that the radio's display mode is turned on. With the radio off, press and hold the "CD Mode" button. Then, press the "On/Off" button. This will toggle the display screen on and off. With the CD Mode button held down, use the volume up/down controls to adjust the brightness of the display.
  • 2
    The system has no sound.
    Bose recommends checking the volume controls to make sure that the volume is high enough and that the radio is not on mute. After inspecting the volume, check the functions. If a CD will not play, check that the CD was correctly loaded and is seated properly on the lock. Some Bose radios can only play Audio CDs, so MP3, Audio DVDs and data discs will not operate. If the radio will not play an external device like an iPod, double check that the item is plugged into the "AUX IN" port correctly, the radio is set to "AUX" and the device is turned on.
  • 3
    Troubleshoot the remote.
    When issues arise with the remote control, check the battery. See that it is loaded in the correct direction. Many Bose remotes are powered by circular batteries, such as those used by watches. Check that the battery is seated properly. Bose recommends that the sensor on the radio be cleaned of dust and cleared of obstruction.
  • 4
    Fix issues with radio reception.
    The primary issue with the Bose Wave's radio reception is typically its proximity to the television. Many television sets emit electromagnetic waves which interfere with radio reception. This will block many weaker radio frequencies, especially AM stations. Fluorescent and halogen lamps and lights with any type of dimmer control will add the same type of interference to their immediate area, so keep the radio clear of those spaces.
    If issues exist with FM reception, extend the power cord as far as possible as the FM antenna is located inside of the power cord.
  • 5
    Remedying CD issues.
    As previously stated, older Bose Wave radios cannot play MP3 or Audio DVD discs. Make sure that the disc has been recorded as an Audio CD. Store-bought CDs are audio discs, but discs burned on a computer should be double-checked with the PC's burning software. Double-check that the CD is clean and free of dust. A soft cloth, like those used to clean eyeglasses or a camera lens, can be used to wipe fingerprints or dust away.
    Check that the radio is functioning correctly. Make sure the mute is off and that the radio is set to "play" and not "pause." Test the player by trying another CD, as this will show whether the original CD was defective.
  • Posted on Dec 31, 2010
    Unable to set clock on pioneer super tuner IIID - tried holding down clock button but time doesn't flash. Your assistance will be appreciated thank you
    To set up the clock...
    Turn radio off.
    Hide clock face.
    Press and hold a few seconds “clock button” to bring clock face up.
    Press and hold “power on button” till clock starts to blink.
    The 4 buttons in a cluster on the right under audio, move the hours and minutes.
    press power when done.
    I hope this helps
    Please rate accordingly
    Thank you
    Computerrep
    Apr 27, 2008 | Car Audio & Video
    Brookstone clock time problem
    Possible that your clock processor section is having some issues. it could be the crystal/ processor or associated circuits. What you can do is only externally trying to reset the device,try to use a hair dryer to warm carefully for few minutes so as to activate any capacitors/ connectivity faults. it this works, do a good cleaning careful not to damage any parts. Helpful. Good day
    Jul 04, 2010 | Audio Players & Recorders
    How do I set the time.It keeps jumping back to alarm time.Thanks
    You can try downloading the owners manual from Sony's site. It looks to me like it may be a bit tricky without the instructions.
    Give this a try.
    http://esupport.sony.com/US/perl/model-find.pl?mdl=ICF-C253&PRODTYPE=32,33,63,71,7,102,80,26,72,44,55,27,74,84,57,61,103,89,10,35,78,48,77,29,50,39,64,41,58,12,52,81,60,66,101,45,73,86,76,62,54,67,70,68,2,17,1,88,100,82,25,28,83,69,59,49,24,104,53,79,22,42,46,13,6,85,3,36,9,51,47,38,4,34,37,43,5
    I hope this information allows you to resolve this issue.
    If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
    Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
    If you need further assistance please comment to this post and I will try to help you further.
    Thanks for using FixYa
    asnowman
    Feb 08, 2010 | Sony ICF-C253 Clock Radio
    Radio of Durabrand Clock Radio WA-211C plays every hour on the ho
    Thank you very much for your reply; I think I may have solved the problem by changing the Time settings to 24 Hour, rather than a.m. / p/m. I did this yesterday evening and the radio didn't come on every hour for a few seconds as it had been doing so I'm hoping this solves the problem, although there doesn't seem to be a logical reason why it should! I haven't yet tried setting the alarm function, so I can't be 100% certain that the problem has gone but I am hopeful.
    On the basis that I had tried everything else, this seemed to be the only (last) possibility available; once again thank you very much for your reply - I don't know whether this solution is helpful to you.
    Barry Sykes
    Dec 29, 2008 | Durabrand W375-K Clock Radio
    12:33 keeps flashing
    Hi - You can download the manual from the link underlined in blue below:
    moz-screenshot.jpgRCA RP5420
    Please update the question & let us know if the information given was useful to you - Good Luck!
    Jul 31, 2008 | RCA RP5420 Clock Radio
    Clock radio frozen in time
    I have it too, and I think it has something to do with the timezone, so try resetting your timezone, and then the clock. it was happening to me, and I fixed it somehow. hope that helps.
    Nov 25, 2007 | Memorex iWake MI4004 Clock Radio
    Magnavox CD Player Clock Radio not working
    This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
    Nov 15, 2007 | Emerson Smartset Clock Radio
    Changing between the buzz and cd setting for alarm clock
    From the manual (miraculously, I still have it)...
    To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
    If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
    When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
    SNOOZE-BOOST
    To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
    Sep 14, 2007 | Sharper Image SI686 Clock Radio
    Bose Wave Radio Logo
    101 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Electro Med Services...
    Ben Armstrong
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
