Question about HP Computers & Internet
I was talking to a tech last night and she told me to so the following. Run the"HDD Self-Test. I ran the short one and it passed. Then I ran the long one and it failed. This was checking my hard drive she said. She said my hard drive might have some bad sectors. I am send you another e-mail right after this one telling you the type of computer I have. I ran the dfranged test. My name is Carol Starling and my E-mail address is cstarling002@nc.rr.com
Was wondering if you knew a guy named Leroy Horne that lived in Fayetteville?
Posted on Sep 16, 2008
Error code 0f00:131b
Most likely hardware. Run a chkdsk on the drive you will have to do it from command prompt.
Example: ckhdsk c: /r/f
Mar 29, 2013 | Dell Studio Xps 9100 Desktop Computer
Inspiron 530s diagnosic test error on hdd: smart short self test - timed out
No your hard drive is just fine.
It sounds like a variant of the S.M.A.R.T. HDD virus. You can try to remove it with the software I list below, but if that doesn't get rid of it you will have to bring it in to a pc shop that speciallizes in virus/malware removal for a set price. Especially if it has started removing your icons already.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
First try malwarebytes anti-malware it's FREE and it's here:
http://majorgeeks.com/downloadget.php?id=5756&file=15&evp=693ee0b20204960edfd909666f809b26
Make sure to select the non-pro version.
Install and use TDSSKiller also (Also FREE):
http://majorgeeks.com/downloadget.php?id=6895&file=1&evp=6ee854ea7c22f46734f10d4e193d17ce
You can try Superantispyware as well (Also FREE):
http://majorgeeks.com/downloadget.php?id=5116&file=15&evp=4b877f10ddee47cecae8038a2f67054e
If you don't have a good anti-virus program already you can use Avira. It's FREE as well, just make sure to configure it to "Select All" Threat categories. Here it is:
http://majorgeeks.com/downloadget.php?id=955&file=15&evp=b7cc93b8a46387032dd7756deb50bbbd
Jun 26, 2012 | Dell Inspiron 530s Desktop Computer...
Trying to reload Windows OS. Run into
From another computer build a msdos floppy disc, yes floppy disc.
I believe you computer accepts floppys does it not? and i also asume you are running xp, you can try running the startup disc and trying to check disc, but if you cannont procede, i would opt into downloading another copy of the windows and try installing through that method. If the disc dosent load, and you get that error message of the bat, another step will be waiting for you.
May 26, 2012 | Dell Dimension 8400 PC Desktop
I got a Lenovo ThinkCenntre M58P with Win7 64-bit OS. If I had a power failure the machine doesn't startup from the HDD as it gives an error that it cannot see the OS. When you check in the BIOS, the...
Reconnect both connection to harddrive then when you power up the computer press F8 key 5 to 6 times untill you see the safe mode and other menu if you are able to enter in safe mode then os still fine run 'chkdsk /r" in run but if you are not able to enter in safe mode or same error then need to check with bootable windows disk insert that disk set first boot device as cd/dvd rom then boot with windows disk then follow the procedure if it able to see windows then repair it .then it will working again. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2011 | Lenovo ThinkCentre M58p 250GB HDD PC...
Dell Dimension 2400 What is Targeted Read Test WHD-20-2RQ and Smart Short Self Test WHD16-FTD and how do I fix it if it said they failed
These are results of two sections of Dell Diagnostics tests which can be run by pressing F10 at startup.
You would have to watch them run to see what has failed during the test.
From Targeted Read Test WHD-20-2RQ failed, could be failure to read RAM (memory), CD/DVD Drive, or Hard Drive.
Something failing within Smart Short Self Test WHD16-FTD could literally be anything within the computer, without seeing what has actually failed during the test.
Sep 05, 2011 | Dell Dimension 2400 PC Desktop
Programs shut down at random
Have you checked in your case to see if all your fans are working? May be a heat problem in power supply, CPU. Get this software and install to check the actual temps on your motherboard.
This is the free program I use.
http://download.cnet.com/Motherboard-Monitor/3000-2086_4-10518386.html
Here is also a website that talks about overheating problems and solutions
http://hubpages.com/hub/How-to-check-CPU-temperature
Apr 26, 2009 | Gateway GT4022 PC Desktop
How to fix Hp slimline Error Code BIOHD-5
1. Restart the computer.
2. Keep tapping the F10 key when the Compaq logo appears. BIOS Setup Utility.
3. Select the Diagnostic tab.
4. Select the "hard drive self test" option and press enter to perform the test. Note: This test takes atleast 40 minutes. This will take you to
Pass - The hard drive is not damaged.
Fail - The hard drive is damaged and may need to be replaced.
Mar 09, 2009 | Computers & Internet
Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Feb 01, 2009 | Dell Dimension 4700 PC Desktop
Hard drive not recognized
If the HDD is not being detected in BIOS...
--- Then first thing u have to do is to reseat the HDD cables both data and sata cables....
-- If still not displayed in HDD---needs to replace the HDD.
--- If displayed----Then enter into BIOS----select ur HDD from the list---select smart support and then run the samrt short extended test.
If test fails then needs to replace HDD.
Thank You...
Nov 07, 2008 | HP Computers & Internet
Laptop help
yes, may be the hard drive... so goahead and run a test on hard drive....
try going to bios setup.... from the main menu in bios... highlight the hard drive... maybe displayed in first drive, or second drive...push Enter... and from the list select an option smart self test...
There would be two test's one is smart self test and smart extented self test... first select the smart self test... it would go up to 5 min... if it is pass go to second test...ie., smart extended test...it would go upto an hour.
If first test fails... no need to run the second...directly replace the hdd... but if pass go to second.. and check the hard drive..
As you said you are using UBUNTU.... try install it again.. if hdd both test pass..
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
