Question about Electrolux FEQ332ES Dryer
I have an Electrolux front load dryer Mo. # GLER331AS2 and the drum is no longer turning but the belt is in good condition. What could be the problem. The motor sounds like it is working when I use the start button but, it is not turning the belt.
  • Electrolux Master
  • 7,482 Answers
Your belt may have slipped off of the idler pulley, or maybe the belt idler spring has come unhooked from the belt.
I will include a website that shows the belt configuation...
Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Posted on Dec 31, 2010
Fridgidaire model gler331as2 drum wont turn with full load
The belt may be worn and slipping or the belt tension idler may be failing or broken
Sep 10, 2012 | Frigidaire GLER642A Electric Dryer
Dryer drum won't turn
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Sep 30, 2010 | Electrolux EIGD55H Dryer
When you put a load in to dry,and turn it on.it starts to make a high pitched squeaking noise when the drum is turning.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine.
Note: This method works with most front loading machines.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Sep 18, 2010 | Dryers
I have a DHDSR46EE1WW dryer..it starts to squeak real loud once it starts turning when clothes are loaded would could be the problem
If you have a front loading machine,
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 13, 2009 | General Electric DHDSR46EGWW Dryer
There is a squealing noice as the the drum turns. It does'nt make the noice all the time but at least 3/4 of the time. It seems to get louder the longer the dryer runs.
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Nov 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
When the dryer is running it makes a loud noise like the belt is slipping?
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
You can also check the belt and the idler roller with the drum out to see the condition and if they need to be replaced.
Good Luck,
I hope this helps
Oct 11, 2009 | Hoover Dryers
Whirlpool Electric dryer won't start
Your problem sounds like it could be a broken belt, faulty motor, or maybe the belt has slipped off of the motor or idler arm pulley.
You can try this first:
Uplug the dryer, reach inside and try to turn the drum 1/4 to 1/2 turn, the plug the dryer back in, and push the start button. Sometimes motors will get dead zones in them and this will move it from that zone.
If you attempt the repair, and if you have a front loading machine, you would remove the front of the machine, this will expose the drum and belt, you can now check the belt to see if it is ok. If it is ok, then you can remove the drum and belt and this will expose the motor, idler arm with pulley and drum rollers.
While you have the drum out of there it is a good time to check the condition of the drum rollers to see if they have flat spots on them, if they do have flat spots on them, then need to be replaced. If not then I recommend that you lubricate them at the shaft with a good grade of Machine Oil such as 3 in One oil. This will save problems later.
Good luck,
I hope this helps you
Oct 04, 2009 | Whirlpool LER5636P Electric Dryer
I have a Frigidaire Dryer Model GLER331AS2 it gets hot but want tumble. What's wrong?
okay, my name is Marc, whites appliance repair, manually turn the drum, if it turns easily, your belt has slipped or is broken.
Aug 18, 2009 | Frigidaire Dryers
Electrolux FGX831FS1 dryer drum, only spins one way manually
Check inside the drum to make sure the three screws in a triangle in the rear center are all there, if they fall out the drum goes off center and the motor can no longer drive it.
This model has no rollers, the front of the drum has plastic glides mounted on the front of the drum that ride on teflon impregnated pads that are glued around the door.
The rear is supported by a steel ball screwed to the rear of the drum (the 3 screws that I think are causing your troubles) that rides in a plastic saddle screwed to the rear of the machine.
If the excess drum movement is only up and down you should replace the front glide system.
Good Luck
Quentin
Apr 26, 2009 | Frigidaire FEX831CS Top Load Stacked...
Electrolux Lavamat Turbo 16830 Washer/Dryer but dryer not working
Has the little belt on the dryer turbo come off? or is the turbo seized - it should turn freely by hand. You may need to replace the turbo fan if the belt keeps coming off - the pulleys can get out of alignment, ie not running parallel to each other - they tend to be cheapo plastic construction these days. Could also be dryer elements or thermostat problems, or blockage with lint causing reduced air flow and overheating - but check belt first.
Nov 28, 2017 | Electrolux EW1209i Front Load Washer /...
Electrolux FEQ332ES Dryer Logo
170 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
