Question about Xerox Office Equipment & Supplies
Error message H 4 - Xerox Office Equipment & Supplies
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Jul 08, 2008
Error message: "disc is unredadable", this is new
Here is the Microsoft solution page for this error. Try steps 3, 4, and 5.
Mar 09, 2011 | Microsoft Xbox 360 Console
Webpage error details
100% working IDM fake key block problem
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Mar 16, 2010 | Microsoft Internet Explorer 8
Precor m 9.5 error code 4
Precor Error 04, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 04
Mar 02, 2010 | Exercise & Fitness
Our Jura coffee machine S9 model has error message Malfunction 4 appearing, have turned machine off from power swith and left off for 30 secs, still has same error message.
Hi, Printed below is the fault for Error 4:
STEAM: Temperature sensor notify “value above tolerance”
I hope this helps.
Alison, Uno Coffee Company
Feb 11, 2010 | Coffee Makers & Espresso Machines
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error Messages
All you can do is look at the manual provided or go to the manufactor website.
Rate 4 diamonds
Mar 02, 2009 | HP LaserJet 4 plus Printer
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
