Question about Fisher and Paykel Refrigerators
We have a F&P FPGKRCGBS Side by Side Fridge Freezer with a water and ice dispenser in the door. Product Code 10630. Unfortunately the plastic water feed pipe ices up and stops the water dispenser working. It appears to be blocking at the dispenser end. Any assistance would be great thanks
5 Suggested Answers
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
  • 33 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Posted on Nov 30, 2008
stedelaney
  • 7 Answers
SOURCE: I can not connect a pipe to the fridge to dispense...
no to use the ice and water feature you need to plumb it in you can use with out plumbing in but not if u want the ice and water function
Posted on May 22, 2010
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
Maytag fridge side by side freezer door leaks water
If the insulation in the door has blown, it cannot be replaced. If there is a dispenser in the door, look at all the plastic parts for any splits or leaks. To test if it is the dispenser, turn off the water supply for a few days. If the water stops collecting in the door it's a good sign.
Apr 22, 2014 | Maytag MZD2766GES Side by Side...
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
The water solinoid is not sending water to my ice tray
Had the same problem. As long as the ice machine is still moving, meaning its working but just no water is getting to the ice tray.  order part #2205762 valve, solenoid and change it out.  It is not hard to do if you pay attention to how you take the old one out.
Feb 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Dispenseer
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control
Dec 31, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
26 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
