How do service valves work on a york condensor model #h2c8024so6b
  • 1,772 Answers
Hello and I hope this helps you out.
Service valves or ports are usually present on the refrigeration lines near the compressor. to permit testing the condition of the air conditioning system and permit removal, replacement, or additions to the refrigerant in the system.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
I am working on a Trane 900, model TTD730B100A1. I fear the condenser is filled with lawnmower debris.
The leaks are most likely on a flare nut joint, on a isolation valve on a split system, on U tubes on the condensor or evaporator, shrader valve on service ports, and may leave wet trace of oil stain.
A condensor should have the small copper line leaving the unit warm to touch, 110*F, if the condensor radiator is clogged from airflow the temperature will be higher and if the temperature is low as ambient, it may need refrigerant and gree air flow is not yet considered a problem
Sep 03, 2015 | Heating & Cooling
Gaggia titanium silicon tube pulled loose by mistake. Where does it go?
Sounds like to pulled the tube by the door hinge. that should go from the door to the steam valve.
If you pulled out for the door then you can reinstall, but you need the plastic insert that holds the tube.
If it's from the steam valve you will need to open the machine or go to a service center to re-install it.
New York Service Center:
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 21, 2013 | Coffee Makers & Espresso Machines
LOOKING FOR THE WIRING DIAGRAM FOR YORK CONDENSOR H2CB060S46C. THANKS
Call York but the units only got 2 sides of power and a compressor and fan motor! L1 and L2 go to common and run on compressor and run cap to run and start on compressor condenser fan will be powered off the contactor, there really isnt much to be worried about with any diagram? what specifically are you trying to figure out?
Feb 22, 2012 | Heating & Cooling
I need a tripper for a york swimming pool model 1104fm
Timer is not identified.
1) Tork makes 40amp 240Volt 1104
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Tork 1100 series uses Tork p47 tripper.
2) Add a comment with photo of your timer posted on Flicker for possible identification.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 13, 2011 | York Hardware & Accessories
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
I have a mitsubishi dual zone unit, model mum18nw
Why would you want to close the service ports of one of the units? It is not advisable, but you can do it. You would have to ensure that the second unit does not start or you risk damage to the compressor and control board.
service manual at this page:
http://www.mrslim.com/UploadedFiles/Resource/OB%20202%20MUM18N%20Technical.pdf
Aug 21, 2009 | Heating & Cooling
My condensor is frozen and the furnace fan is humming
you have a bad fan, or something stopping it
your coilsd arfe frosted over becuase they are not getting propper air flow across them
Aug 10, 2009 | York Furnace Draft Inducer Blower Fasco #...
York high effenciency furnace not firing all the time
has anyone worked on this furnace because the error would indicate that the positive 120 volt and the neg 120 volt is swapped , these units will also do this when the ground wire to the furnace or gas valve or furnace or @ the panel is lose , corroded , or missing , the gnd must be present to open valve , I am aware that ac is is not usually polarity sensitive but in this case it most certainly is ...have seen many time and know it to be true
Dec 27, 2008 | York Yankees Bedding MLB Comforter
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
