Question about Brother MFC-9840CDW Laser Printer
The printer screen shows change parts and on the wlan computers connected to it says that the drum end soon and that panics me a lot as i paid a lot for this damn computer
    Genius:
  • 1,739 Answers
Did you recently replace the drum and the warning is unexpected?
Why does the message "Drum End Soon" continue to appear on the LCD after I replaced the drum?
Description:
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
You can use this procedure to reset a drum in order to continue to use up the remaining 'life' of the drum; recognizing that you will need to replace the drum when you start having print quality issues.
You may find this site very useful.
Trust this is helpful. Please vote.
Posted on Dec 31, 2010
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
It say drum end soon and i dont know what this means as i put a new ink cartridge in it and it still keeps coming up the same.
Your unit obviously has a separate drum and toner.
Changing the toner, doesn't change the drum.
You will need to change the drum soon.
Jun 24, 2011 | Brother Office Equipment & Supplies
Drum Error - see routine maintenance chapter in user guide. Do not have user guide
I tried everything and then decided to slightly change the above instructions to:
Open the front cover
press Clear/Back
Replace New Drum - select "Yes"
after the screen will show "accepted"
close the front cover and you are good to go
and WA LA it worked!!
Apr 19, 2011 | Brother MFC-7340 All-In-One Laser Printer
Printer says "drum end soon". I don't even know
The drum is the part of the printer that the image of what you want to print is stored on by a laser drawing on that drum. That drum is then charged with an electrostatic shock that will draw up toner particles from your toner tray that will eventually be transferred to a piece of paper that will be heated to fuse the ink particles on the paper. That drum is photo sensitive and eventually looses its ability to be charged. You will then have to replace that drum.
Feb 09, 2011 | Brother MFC 7840W Printer
Drum End Soon
You will soon need to replace the drum. Its considered a consumable just like the toner cartridges. You can purchase the drum anywhere that sells brother pruducts.
May 24, 2010 | Brother HL4040CN Laser Printer
My hl 4040cn says drum ends soon. do I have to
Yes, The drum units have a set number of copies before they need to be replaced. This printer has a drum life of 17000 pages. The part number for the drum is DR110CL Just do a Google search or check your local office supply store.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 05, 2010 | Brother HL-4040CN Laser Printer
How to reset drum counter for brother hl4070cdw laser printer
When you replace the drum unit with a new one, you need to reset the drum counter by completing the following steps:
  1. Turn the printer power switch back on.
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
Mar 27, 2009 | Brother HL-4070CDW Printer
Drum Ends Soon
you need to replace the drumkit, or have it replaced.
Oct 24, 2008 | Brother MFC-9440CN Laser Printer
Brother MFC-9840CDW Laser Printer Logo
400 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
