Question about Garden
How many watts does the generator produce on a miller big 20 welder/generator
  • 7 Answers
SOURCE: Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Posted on Feb 04, 2009
  • 154 Answers
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Posted on Jun 14, 2009
RixsFixes
  • 2200 Answers
SOURCE: looking for an instruction manual for my miller 225g plus
You can get this manual from the following link http://personafile.com/Miller-Welding-Equipment-BOBCAT-225G-P9207349821373.htm
Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
SOURCE: I have this Miller
go to the miller website and download the manual. the scematic is in the manual
Posted on Mar 29, 2011
heatman101
  • 43501 Answers
SOURCE: Our Homelite model 5500 generator
The problem when that happens is usually a loss of residual magnetism...by flashing the generator you can recharge the permanent magnets, and then the generator will work again.
Generator Flashing
This link gives one way to do it.. there are others if your google it...look a few posts down to find the procedure...
heatman101
Posted on Jun 08, 2011
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
Do I need a battery hooked up to a miller 225dplus for it to generate or weld
No , as long as the engine is running it should be producing power .
Dec 07, 2014 | Miller Welding Tools
Miller welder problem
If it has a timing belt it broke or lost a few teeth. The camshaft became disengaged from the crankshaft. Any Automotive mechanic can fix it.
Jul 30, 2014 | Miller Big 20
Gas runs out of carb drain on miller welder generator 301g trailblazer
if it is the float bowl drain leaking, close the drain. If it is the vent, clean float bowl and needle and check level. Next time, drain the fuel out of float bowl after you run it if not planning to run it for 30+ days. That is why they put drains on generator carbs. Modern ethanol turns to gum real quick. Tell you congressman you think ethanol sucks and the new 15% ethanol the farm lobby is trying foist off on us is going to be a disaster for small engine owners.
Apr 10, 2013 | Miller Trailblazer 301g Cc/cv, Ac/dc...
Engin boggs down while welding
have you had the cables tested,welding weares them out.how old are they a welder is like a big old coil or armature the contact points on it gets corroded causing it to work harder causing your bog
Apr 08, 2012 | Miller Trailblazer 302 Welder Generator...
Generator rus fine but does not produce power
check the brushes at the armature,armature should be shiney,if not take emory cloth and clean the armature,see if that helps.
Jul 06, 2009 | Hobart Welders Champion 500433A Factory...
Arc start board
At your nearest Miller distributor (almost all gaz reseller)
Jun 03, 2009 | Hobart Welders Champion 500433A Factory...
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
