Question about Briggs & Stratton Garden
I have a morrison classic 35 that is surging while its running, it runs well except for the surging. am guessing plug gap is 20thou and have cleaned everything. it seems to be the arm that comes off the flywheel and controls a possible butterfly valve in the carb that is behaving erratically
  • 183 Answers
Your Briggs & Stratton Classic engine uses a diaphragm to pump fuel. Yours has deformed and needs to be replaced. It is a very easy repair. Remove the air filter. There is a bolt on the end of the fuel tank nearest the spark plug. Remove this bolt. There is another bolt just behind the carburetor that holds the tank to the engine. Remove this bolt also. Now you should be able to gently pull the tank away from the engine. After the carb clears the intake tube, you can tilt the tank enough to remove the governor linkage from the carb butterfly shaft. Now the tank/carb assembly is loose and in your hand. Go to the workbench. There are 5 screws that hold the carb to the tank. Remove these 5 screws. When you lift the carb from the tank, you will see the diaphragm gaskets. Remove the old and install the new set. The 2 part diaphragm set consists of a rubber diaphragm and a paper gasket. The rubber part goes against the tank, then the paper gasket, then the carb. Leave the screws in the carb as you reinstall it, and the screw tips will align all parts during reassembly.
The diaphragm set is readily available at any Briggs parts dealer or online. Make sure you take the Model, Type, & Code numbers with you when you go for parts. These numbers are stamped into the metal fan shroud just above the spark plug.
Posted on Dec 31, 2010
Testimonial: "Thank you very much you're advice was very useful and i can understand all you're instructions easily. I will update with results soon"
  • David Goheen Jun 05, 2013
    excellent solution, and guide. I never would have stumbled upon the method of removing the carb from the tank by myself. Also, the diaphragm/gasket, although available from B&S, was much cheaper on ebay.uk.
Lawn Mower Surges
Check valves. Vacuum from the engine draws the fuel in...sounds like vacuum is surging. Also it may have a "fuel pump" that may be bad
Aug 24, 2016 | Briggs & Stratton Garden
My Morrison weed eater keeps dying out I'm guessing it may be the carburetor dirty? I'm just guessing. What do you think the problem maybe?
If it starts and runs for a couple seconds and dies then yea, most likely it is the carburetor. If it runs for longer than that it will be something else
Feb 04, 2016 | Garden
Spark plug gap settings chart and points gap
What make of motor and horsepower,plugs normally 25thou inches.evinrude Johnson below 40hp points 20thou inches,55hp and up 10thou.to take flywheel off you need a puller
Aug 24, 2014 | Boating
Gap difference .35 to .45
88 through 95 rquires a gap of 35 check the label under the hood to see if its different if it is follow it instead. Also check the firing order to make sure you didnt cross any wires and make sure the boots are in all the way on the plugs your truck shouldne be acting like that just from changing the plugs.
Dec 22, 2009 | 1990 Chevrolet K1500
1988 2.5 intermitant runnibilty problem, acts like its running out of fuel but fuel pressure does not drop off
Have you turied a new ign. module. It is located in the dist, underneath the rotor.
Nov 16, 2009 | 1988 Chevrolet S-10
The Proper plugs
should be around .30-.35". You most likely have a dirty carb issue which will cause the bike to run poorly at lower RPMs as this is on a different fuel circuit in the carbs, know as the pilot jet. You may be able to run some carb cleaner through them. I recommend seafoam, or chevron techron. Mix according to the instructions on the bottle.
Jun 10, 2009 | 1998 kawasaki VN 1500 Vulcan Classic...
P1401 still after replacing EGR pressure and EGR valve
Yes that is what is wrong the intake manifold is plugged with carbon restricting EGR flow you need to clean out the ports to correct the problem if you run the car to long you will burn the DPFE ( the EGR pressure sensor ) out agian
Jun 06, 2009 | 2000 Mercury Cougar
Garden Logo
802 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
