What does ld stand for when the washer stops and starts squirting from the top seal of the washer
  • Washing Mach... Master
  • 3,361 Answers
LD=Long drain.
Remove the lower front panel and clean out the drain pump.
Posted on Dec 31, 2010
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
LD = Long Drain
ld flashes when the water level does not change after the drain pump is on.
Is the drain hose or the drain pump clogged?
Is the drain hose height greater than 96? ?
Is the pump running?
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine stops during cycle
"LD" stands for long drain meaning that the pump could be bad or that it just needs to be cleaned out.
Jul 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Top loader washer wtw6400sw3 will not finish drasining. beeping and flashing Ld
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies. Can I hear an Amen?
Aug 10, 2009 | Whirlpool WTW6400SW Top Load Washer
My washer has an error code ld and it wont start or turn off i have to unplug it to turn it off now its stuck on on how do i fix it
"ld" stands for long drain. check the water pump for any obstructed items like coins, hair pins or clothing. the water pump is located in the bottom of machine in right back of stator. remove hoses and clean. also check the air dome located in bottom of basket.
May 05, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
On my whirpool washer LD light lights up and many times drain cyc
ld stand for long drain there is something in your pump or your drain most likely the pump you need to clean the pump or maybe even replace it if need be
Dec 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Water leakage in dishwasher? Cant turn on. Model LD-12AW2.
possible you have not pushed seal in far enough hence door not closing fully. press fairly hard and see if it then starts
Jul 01, 2007 | LG 24 in. LD-12BW5 Free-standing...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
