Question about Sharp UX-B750 Inkjet Fax
Fax stored in memory; how do i print? - Sharp UX-B750 Inkjet Fax
  • 71 Answers
Hi
first make sure you have paper and ink in the fax. If you do, then unplug it for a min. It will hold the memory when unplugged. When you plug it back in it should print out.
Good luck
Posted on Dec 31, 2010
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
MY FAX MACHINE CAN NOT RECEIVE FAX FROM OTHER, THE DISPLAY IS FAX MEMORY FULL, HOW TO SOLVE?
This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Mar 15, 2011 | Computers & Internet
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Can you retreive a sent fax from memory
The fax element of the Printer contains a memory feature for storing faxes in the event of a printing problem. This feature is useful for protecting yourself against missing faxes if your printer runs out of paper. In order to retrieve missed faxes, the feature must be switched on when the faxes arrive. You can reprint faxes stored in the device's memory from the main control panel. You should allow approximately 5 minutes for this task, or longer if many faxes are stored in the memory.
Instructions:
Load paper in the input tray.
Press the "Setup" button on the front of the printer.
Select "Tools," then "Reprint Faxes From Memory."
Press "Cancel" to stop printing. Faxes are printed in reverse order; the most recent fax is the last to print.
Dec 03, 2010 | HP Office Equipment & Supplies
On the display it is saying there are faxes stored in the memory.how do we retrieve them from the memory.
You didn't indicate what model fax printer this was...
Most machines will have a menu button. Hit it, enter fax options, and select memory print or print stored (or similar wording).
Sometimes, just hitting the fax mode button will bring up a prompt asking if you want to print the stored faxes (or delete them).
Jun 13, 2010 | Office Equipment & Supplies
Memory is full
Please follow this instructions; i don't know whether you've disconnected or not but it's been disconnected from my side. So i just wanna give some more hints to fix your problem;
Press the Menu key on the control panel.
Press the Up or Down Arrow key until Fax appears on the LCD.
Then, press OK.
Press the Up or Down Arrow key until Remote Fax Opt or
Advanced Fax Operation appears and press OK.
Press the Up or Down Arrow key until Fwd/Page/Store or
Forward/Store appears and press OK.
Press the Up or Down Arrow key until Off appears and press OK.
If you have faxes stored in the memory, you will receive a message that reads Erase All Fax? 1. Yes 2. No.
Or
Press the Menu key.
Then, press OK.
Press the Up or Down Arrow key until Print Fax or Print Document appears and press OK.
Press Black(Mono) Start.
Good luck. Thanks for using FixYa.
Jun 01, 2010 | Brother MFC-5460CN All-In-One InkJet...
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Please assist me in printing a fax message that is stored in the memory of my Canon MX310.
Hi there
Before printing an actual fax, you may want to see a list of faxes stored in memory. To do this:
  1. Press the FAX button, then press the Menu button.
  2. Press the or button to select MEMORY REFERENCE.
  3. Press the OK button two times.
  4. The memory list is printed.
Note:
  • If there are no documents stored in memory, "NO DOC. IN MEMORY" is displayed, and the machine returns to the previous screen.
  • In step 2, you can also select PRNT REPORT/LIST (see Summary of Reports and Lists) and then MEMORY LIST to print the memory list.
  • If you have canceled receiving a fax in progress by pressing the Stop/Reset button, the fax may be printed after the memory list.
Now, when you're ready to print the specific fax you like, please do the following:
  3. Press the OK button.
  4. Press the or button to select PRINT DOCUMENT
  5. Press the OK button
  6. Press the left or right button to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number by pressing the Numeric buttons. If you are unsure of the transaction number, print the memory list. See Printing a List of Documents in Memory.
  7. Press the OK button
  8. Press the left button to select YES to print the first page only, or press the right button to select NO to print all pages of the document.
  9. Press the OK button.
I hope I have been of some help.
Best regards
nLinked
Jul 03, 2009 | Computers & Internet
How do I print off fax in memory Panasonic model no KX-FP215E?
when msg is displaying on screen fax in memory .install paper and press fax start key.all faxes in memory will bi print.by mian jee
Dec 02, 2008 | Panasonic KX-FPG378 Fax
Sharp UX-B750 Inkjet Fax Logo
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
