Question about Brother MFC-5840CN All-In-One InkJet Printer
Brother MFC-5840CN unable to scan
Please help! On the fax part of the machine I manualy tried to fax a document. I think what happened was once I started to send, someone was already on the line. Can't see why this would cause this problem, never the less something did.
I am getting a message on the machine "unable to scan see troubleshooting and routine maintance chapter in user's guide. I followed all the tips to correct and still not working. Never had any issues at all until this. Any help would be greatly appriciated!
Thanks
  • Ed Mulrooney Oct 07, 2008
    Tried to fax through the document feeder. Error message appeared on LCD
    Unable to Scan. See Troubleshooting and routine maintenance chapter in
    the User's Guide. Checked for any obvious problems. Cycled power.
    Scanner makes two calibration passes and then states the same message. Help!
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Posted on Nov 06, 2008
    Problem Solver:
Went to http://welcome.solutions.brother.com downloaded lasted firmware to the printer. Error message went away after update. Sent a facsimile successfully.
Posted on Oct 16, 2008
UNABLE TO COPY
Posted on Sep 03, 2008
I am unable to scan anything to the email,doc.,file or anyththing. whats up?? dbh511@hotmail.com also need to change email from outlook express to hotmail. How??
Posted on Sep 08, 2008
MFC-5840CN All-In-One InkJet Printer: Unable to clean...
I would like to know what exaclty are u trying to clean..
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/000200/000061/faq000261_034.html?reg=as&c=au&lang=en&prod=mfc5490cn_all&Cat=7
for a more detailed cleaning follow this HP document and check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01427322&cc=us&lc=en&dlc=en&product=3692888
May 18, 2010 | Brother MFC-5840CN All-In-One InkJet...
How to scan the documents using MFC-5840CN
Use your factory CD or visit www.Brother.com and install the Control Center 3 (CC3) software. Opening the CC3 brings up a menu that lets you scan, edit, and store documents and photos using your computer.
Bill B
Apr 10, 2010 | Brother MFC-5840CN All-In-One InkJet...
The information screen says "Unable to Scan"
The machine has a mechanical problem.
OR
A foreign obstacle, such as a clip or ripped paper, is in the
machine.
Jan 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Product info
yes. It can fax and copy in b/w or color without pc.
Apr 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother mfc-5840cn
press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
Nov 02, 2007 | Brother MFC-5840CN All-In-One InkJet...
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printer problem
MFC 5840cn - lcd shows 'unable to print see troubleshooting and routine'
Aug 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
1,534 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
