Question about Magic Chef 31000 Gas Kitchen Range
The oven door handle fell off can i take the door off to repair it ?
  • Magic Chef Master
  • 3,361 Answers
Yes.
Posted on Dec 31, 2010
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
My ge double oven326b1230p001 the top door is not closing properly and the light keep on,please advise how to close top door
Oven Range Door DIY Repair - YouTube
? 2:50
www.youtube.com/watch?v=6YFTYWsiO1M
Jan 22, 2011 - Uploaded by ApplianceAdvice Watch Queue. TV Queue. __count__/__total__. Find out why.Close ... This video explains how to remove an oven door on many higher end ovens, such as GE, Kitchen Aid, Kenmore, Whilrpool, Dacor, ... Top comments ... fell off and the screws fell down into the oven door and I did not know how to fix it.
Aug 08, 2015 | GE Ovens
Door handle fell off of oven
Rachel, every range oven door I've seen, that was built in the last 20 years comes off the range by opening it about 6 - 8 in. from the top of the door frame, taking a firm grip on both sides about 8 - 10 in. down, bend the knees slightly, get a good grip on the door and pull up sharply. The door should release from the spring hinge on each side. Once you have it out you can lay it flat on the kitchen table, (preferably on a towel or cloth of some sort), with the inside facing up. There should be several screws that hold the interior portion of the door to the outer portion. If you remove these screws you should be able to remove the inner portion of the door, by pulling straight up, easily, and put it on the floor or if there's room, on the counter or table. Now you should be able to locate the holes the screws go into, to hold the handle on the door. If they connect from the interior, you should have found them when the interior was off the first time. Take them and install the handle. If there are none, find some chatterproof washers and put one on the inner side of each screw to keep them from loosening again. Once you have the handle secured to the door you should be able to put it back together. After you have assembled the two halves of the oven door, make sure the two hinge assemblies are pulled away from the frame of the oven at approx. a 35 degree angle. This is necessary to have the proper clearance to allow the door to slide down onto the hinges and grab on inside. The door should slide right down over the two hinges and then you can close it up.
Mar 05, 2014 | Whirlpool Ovens
The door handle fell off my Whirlpool Microwave Hood Combination - GH9176XM. How do I access the bottom screw for the door handle? Thank you
You cannot. you would have to take the door apart and it's really really not recommended as any tempering with a microwave can lead to a radiation leak from the magnetron. ( it's also the reason why as a customer without a repair license you cannot buy any microwave parts except for filters.)
Mar 15, 2011 | Whirlpool GH9176XM Microwave Oven
The handle on the bottom oven fell off. how do i reattach it?
I suppose the handle you are talking about, is the long, wide one, used to pull that oven door open, right? I personally do not have any experience with this particular oven-- However:
These handles are usually held on by a long screw at each end.
So-- when you look at the handle-- do you see where the screws should attach at each end?
And do you see matching holes thru the door-- where the handle was once attached?
Now: Where are the screws?
We know they were there at one time, right?
So-- can you open the door, and can you locate where the screws are now?
Once you locate the screws, can you hold the handle, and re- screw the screws ito the threads in the handle? You have the necessary tools? -- Screw driver and flash light?
When you examine things closely-- get back with us, and we can help you to your next step.
Mack B
Jan 15, 2011 | Electrolux ICON 30 in. Double Wall Oven
My oven door handle fell off
remove the screws and the door will seperate and you can reinstall the door handle.. mm most whirl ovens have lift off doors this may make it easy to work on .. mm hope this helps if more help is needed i need your model # off the tag on your oven .. mm feed back pls .
Nov 25, 2010 | Whirlpool Ovens
Outside glass dooor on Whirlpool oven fell off, what do i do?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 15, 2009 | Whirlpool MH1150XM Convection/Microwave...
Handles fell off of the top oven door on maytag gemini glass top
Open the door a few inches, to the first hold-open stage. Lift the door upward & off the mounting bars. There will be screws along the bottom edge.
Mar 08, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
PLMV169 Door Handle
You can find an exploded view for model PLM168 (it's probably very similar) here: http://tinyurl.com/gv383 It looks like you'd have to gently pry out the choke cover (see attached photo) then you'll see the screws. When you reinstall the door handle screws, add a bit of thread locker or nail polish to secure them.
Sep 20, 2007 | Frigidaire PLMV169DC Microwave Oven
Magic Chef 31000 Gas Kitchen Range Logo
90 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
