Question about Mitsubishi Televison & Video
Mitsubishi digital projection tv WT-42313. When I was watching a program, it turned off. When I clicked it back on it immediately it clicked back off. Any ideas? Nothing was in the troubleshooting section.
  • 57 Answers
Hello my nema is rico and i work on tvs sometimes. first check your power source in the wall, second check your lamp, third check your power supply for cold solder. if the doesnt fix the problem, maybe you have bad sensor ( thermal sensor) or bad main board. please feel free to call me, if you need more help with your tv. 602-810-7149 i live in mesa az
Posted on Dec 31, 2010
WT-42313 - Won't turn on. TV gives and error code of 24. I found that this is an issue with vertical deflection. I need to know how to repair this issue.
Ck pico fuse F9A05 5amps it will be green or yellow looks like resistor if bad, replace Both STK ICs STK394-250 and 2 resistors R8c13 &14 3.9ohms also resolder all 3 yoke plugins on board.
Sep 20, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power on 2 sec. then off won't turn mitsubishi wt-42313
with this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Jun 17, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power light for 2 seconds, then nothing:
send me d model number and i could help most likely u have a powersupply problem
Apr 07, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 TV
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Sep 01, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Turning on my tv set
Same issue - our successful fix, at least temporarily, is to unplug power cable from outlet for at LEAST 4 hours...pref. overnight.
Jul 15, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
http://www.digitalhome.ca/forum/showthread.php?t=21847
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
