Question about Mitsubishi Audio Players & Recorders
I have a mitsubishi HC5000BL projector and it has an audio out put on it and they refer to it as a trigger it is and 1/8 inch headphone jack. but it wont work i went through all the settings and turn the trigger output on but still no sound when i hook up my ps3 through the HDMI. i was wondering if there is a different setting to make the audio out put work
    Brigadier General:
  • 8,546 Answers
The trigger has nothing to do with audio and is to activate another device with a 12v signal, for example the screen. If you run the trigger into an audio device you'll probably kill it.
There are NO audio capabilities in this unit.
Page EN-7, EN-11, EN-24
http://www.retrevo.com/support/Mitsubishi-HC5000-Projectors-manual/id/599ag205/t/2/
Caution:
Do not use the signal output from the TRIGGER terminal as a power for other devices.
Do not link the TRIGGER terminal with an audio terminal of other device because that device may
be damaged.
The rated current for the TRIGGER terminal is 200 mA. If you use a current exceeding this rating,
a failure may occur.
For information about electric screens, please contact screen manufacturers.
Posted on Dec 31, 2010
How to we connect from projecter to tv
depends on what type of output the projector has if it has a round 5 pin connector then you will use an S video cord and a separate audio cord which is either 1/8 inch like a headphone jack with RCA cables plugs on the end or two RCA plugs on each end.
if it has a rectangular connector that is sloped on 2 sidesthen you'll use an HDMI cord which has both video and audio.
if it has three colored circular connectors then you use RCA cables video is yellow audio is red and white or black
Jan 10, 2015 | BenQ Office Equipment & Supplies
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
Im trying to find out where my audio outputs are so i can hook up my surround sound to it..
Hi, if you r are referring to t.v. connections, some flat screens only have 2 audio outputs-one is actually lti up with a reddish glow and is squarish in shape, this is a fiber optic connection that goes to the back of the receiver ( using a toslink connector ) the other audio out may be a small 1/8 inch( 3.5mm) stereo headphone jack-use a stereo headphone to rca adapter cable to plug into an audio input on the receiver. Thanks for asking FixYa, I hope this was of some help, and good luck-Prodzilla
Apr 20, 2011 | Audio Players & Recorders
Hi i would like to know how to connect in ear monitor to my behringer xenyx 1002fx
by in ear monitor I assume you are talking about a set of stereo headphones.
These would plug into the PHONES jack, which is located just to the left of the MAIN OUT jacks.
If your headphones have a 1/8 inch jack, you will require a 1/8 inch female to 1/4 inch male stereo adapter.
These are fairly common, and can usually be purchased at any audio store or Radio Shack or The Source by Circuit City.
Apr 09, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Hello, if I want to hook up an external audio device such as a speaker to my Toshiba TDP-ET20 DLP Projector, how do I do that?
Hey,
You will need to buy a digital coax to an RCA or analog Headphone cable. You will plug the digital coax end of the plug into your "coax out" connection on the back of the project.
The other end will depend on your speakers. If your speakers take an RCA connection (white and yellow cables) then you will buy a Digital Coax to RCA cable. If they take a regular headphone jack then you will need a Digital Coax to 3.5mm headphone jack converter, and plug the headphone jack into your speakers.
Mar 01, 2011 | Toshiba TDP-ET20 DLP Projector
I have a garmin nuvi 360. It has an audio problem. It usually doesn't play any audio unless I plug in headphones or an audio cable. And when I plug in the headphones it only plays through one ear. But if I...
Please see this link:
http://www.sharc.net/gps_audio_repair.htm
Your headphone jack connections have broken inside, cutting off the speaker and one side od the audio, left or right. The jack needs to be replaced or resoldered.
- Jim
Jun 30, 2010 | Garmin Nuvi 660 GPS Receiver
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
How do I play music from my lap top on this sound system?
your laptop has an audio output jack that is 1/8 inch sterio .. your sound system likely has RCA input jacks .. you can get a cable from radio shack that has a 1/8 inch (3.5mm) sterio plug on one end and two RCA plugs on the other ..
plug the 1/8 inch jack into your computers audio output (headphone jack) .. the RCA plugs will connect to the AUX (analog) input on your sound system .. select AUX on your sterio system to select the computers input .. now you should have great sound from your computer . the computer likely provides only sterio information so the multi (7) channel feature of your sound system will have to fake it ..
Jul 24, 2009 | Pioneer SX-315
I bought inspire m4500 but only 2 speakers are working....
put the black pin of ur headphone in mic jack of laptop(mostly red color) and green pin of ur headphone in output audio (mostly green).
hope this helps u.. cheers Rajeish
Jul 05, 2009 | Creative Labs Sound Blaster Live! 5.1...
Audio not coming out input 3 in
input to the tv is incorrect select av3 0r what ever the front jack is marked on you tv. good luck farr64
Apr 30, 2009 | Mitsubishi WD-73735 Television
193 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
