I am trying to scan a pic and my scaner says no scan options
  • shmilebug Jul 08, 2008
    i have a HP officejet J5780 all in one and i can do everything but scan it says no scan options
  • Dave May 11, 2010
    please provide the scanner make/model and the operating system of your PC so I may try to assist you
    Sergeant:
  • 287 Answers
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Posted on Jul 08, 2008
2 Suggested Answers
  • 619 Answers
SOURCE: scaner does not scan
Open the control panel , press scanner icon , set scanner in default / open device manager trace the scanner line if it connected then try to test scan.
Posted on Jan 07, 2008
Why wont my 252bizhub scan
If the actual optic unit wont scan if you mean, check the left side of the scaner the Fix screw might not remove yet.
If the Scan (option) you mean , you have to install the driver to the COMPATIBLE PC. Check the BH-252 specs
Oct 14, 2014 | Konica Minolta bizhub Office Equipment &...
Scaner Short Cut
did u tried to search for the scanner button software ? try to see for it
Jul 23, 2010 | Canon LIDE20 Flatbed Scanner
Scan doc come up as pic only
you have to choose in the software that yu use for seting the format in what you want it to scan ..if it only scan photo like ..it means that it is set to scan as jpeg ...change them on the format u need..from the options before scanning ..
anyway ..Im not sure it has such a feature...but if you say that it use to do that ..I guess it has to be ...be sure that u used the same software before..and didnt had another software to manage the scans..
another thing to try is to ..insert the document in the scaner ..and try to import from scanner into the word directly ..if it has such a feature ..
Mar 11, 2010 | Lexmark X4550 Multifunction Wireless Color...
How to scan photos to the computer
start - program- lixmark scaner- click on it-the diloge window for scaner apper choice the dip as300 or more put 300 is good then choice the jpg for hoto to be very easy when you have save the photo make prevew for the picture the scaner will make scanning for the picture in the glass then will apper on you moniter computer select the part you want scanning by mouse then click scan when finish save it .make sure you instull the scaner in your computer good.
Dec 02, 2009 | Lexmark X7170 All-In-One InkJet Printer
No Scan Options
it is the problem your scaner driver please install it properly then you can scane it
Jul 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet j5780, NOT SCANNING
go to www.hp.com and download a new driver of your scaner for xp
Jul 03, 2009 | HP Officejet J5780 All-In-One InkJet...
I can not scan with duplex option
You will more than likely have to get it from fujitsu. You can contact them at 866-375-3788. It is the ADF optical unit part # PA03338-D820 and list at $1715.00
Jul 26, 2008 | Fujitsu fi-5750C Flatbed Scanner
Scaner
As you have not mentioned your computer set up, I will have to assume you are using a PC and not a Mac and are running Windows XP.
Download Epson Scan (2.7u) from the Epson Web Site. This will enable you to control scanning via PC.
Jul 13, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Pictures
just throw it to rubbish and buy a new one
Apr 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scaner does not scan
Printer works well, but the scanner will not scan only leaves a black page
Dec 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
282 people viewed this question
jasbo
jasbo
