Question about Amana ALG443RAW Gas Dryer
Squeaking while drum spins - Amana ALG443RAW Gas Dryer
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Dryer is squeaking bad
its either the belt slipping .... the motor ....... or the main drum bearing you can take the belt loose and spin the drum and listen for the squeak then spin the motor and listen that should tell you which is causing the squeak
Mar 26, 2012 | Washing Machines
Spinning Motor is overloading
Hi
Thanks for using FixYa. LE error is a communication error between the control board and the motor. In you LG washer the Hall Effect sensor board monitors the direction and speed of the motor and sends this information to the control board. Usually the issue is with this Hall Effect sensor going bad and should be replaced. However, to make sure it’s not a locked motor, try turning the drum with your hand. And, if you feel some resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If it is fine then it is the Sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | LG WM-2277HW Front Load Washer
The dryer is squeaking (especially when it begins spinning), and it spins a little rougher than normal.
The sqeak is from one of two items surrounding the drum. It can be the belt with a bad roller on the belt tensioner or the liner surrounding the round lip of the front part of the drum to the dryers front panel.
If the squeak can be heard dy the dryers door it will be the felt liner. If deeper inside it will bet the belt
Sears has replacement parts online and at all repair centers for sale
Apr 10, 2010 | Amana NED5500TQ Electric Dryer
Our dryer has a terrible squeak. We replaced the
The terrible squeak is probably the idler pulley shaft spalling in the idle pulley mount. When the idler pulley siezes to to pulley shaft it spins in the mount and makes a horrible racket.
It can be the motor bearings also but I doubt it at this time. With the belt off you can spin the motor and listen for any odd sound. If you hear nothing then the problem is definately the idler pulley assy.
It is normal for the drum to float in place. When there is a problem with the drum or drum felts, you usually hear a cyclic scrape or grinding sound that is concurrent with each rotation of the drum.
Kelly
Mar 05, 2010 | Frigidaire GLGT1031C Dryer
Washer runs very loud while spinning and stops very loud. Squeaks and squeals!
Sounds like the main drum bearings have failed. remove drive belt, and spin drum by hand, if it feels rough or is noisy, then the bearings have failed.
Please rate my solution.
Thanks.
Nov 05, 2009 | Washing Machines
Dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Squeak in Kenmore HE 2plus front load washer when drum spins
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Jul 31, 2008 | Dryers
Squeak upon spinning
Hi, I wanted to comment on this because I have the Majestic MJ9200 Washing machine front load for the RV. I am having the exact same problem and I cannot use my machine at this time. This is NOT an unbalanced load problem. An unbalanced load will cause a loud banging noise because the drum is off balance. There is something wrong inside your machine. Mine never had this problem before either and an unbalanced load does not cause this horrible screech while on the spin cycle. My machine like yours made the noise only on certain spin speeds, high 1500 rpm spin the first time and when I adjusted the spin cycle just to see what happened it stopped making that horrible noise. I washed another load and it began that same screetch while spinning and it was then in all RPM ratios available on my model.
My husband took the top off the machine and could not see anything evident but when looking into the front of the machine we could tell that is seems the interior drum is much looser in the washing machine than in the dryer. There are two drums on the front load. A larger outer drum and a smaller inner drum. The inner drum is what is looser in our machine and the noise is a very loud screetch while spinning the water out of the clothes.
Is your machine under any kind of warranty? Mine is not and I am waiting to get it fixed.
Good luck on getting yours fixed and perhaps we can both help each other out on this one although we have different brands of machines...
May 25, 2006 | Whirlpool AWM5145/2 Front Load Washer
Amana ALG443RAW Gas Dryer Logo
107 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
