Question about Kustom KPC10MP 10" Powered Monitor Speaker
Kpc10mp line out jack dos'nt work - Kustom KPC10MP 10" Powered Monitor Speaker
  • Kustom Master
  • 5,603 Answers
These are hard to work on... but one possible thing is if you are using an XLR adapter that is going from balanced to unbalanced 1/4 inch plug. You need to go XLR to XLR on this one. The MONO adapters can ground out the signal as these things don't always drive balanced signals... The signals are also line level so one does NOT want to use an impedance converting adapter.
The preamp is mounted on the plate with the jacks and has pretty short leads that limits how far you can pull it out. Taking off the grille and removing the woofer to get access can be a pain, especially to get the grille back in with the rubber edging.
Of course there is always the possibilty that the driving op-amp on the preamp board could have been fried. Word of WARNING: Power ALL interconnected parts of your system from the SAME receptacle or source. Powering say a mixer from a receptacle at the back of the room and powered speakers from a receptacle at the front is a good way to have equipment fried by "ground bounce" on the power system. Run extension cord to your mixer from the front where speakers are powered!
Posted on Dec 31, 2010
How do i replace fuse in kustom kpc10mp powered monitor
Remove the power module from the cabinet. You'll find the fuse on the circuit board.
Feb 14, 2016 | Kustom KPC10MP 10" Powered Monitor Speaker
How to replace fuse in kustom kpc10mp powered monitor
Remove the power module from the cabinet and you'll find the fuse on the circuit board.
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have got a kustom KPC10mp and i am trying to hook it up to a kustom non- powered and i cant get no sound thru the monitor , Can this be done .The line out dont make no sound when it is connected to the...
In a word, NO. The line out is line level audio... it has NO power amp and cannot drive a non-powered speaker. I have both of these cabinets myself. You need to use an amp with the non-powered speaker. When using an external amp you will need to make sure you phase the two speakers correctely... you could just reverse the speaker leads of the non-powered one if needed.
Sep 11, 2011 | Kustom KPC10MP 10" Powered Monitor Speaker
I have 2 Kustom KPC10MP powered speakers - very new. One has developed a hiss that increases with volume, regardless if there is signal going into the speaker or not. This is a new development as of today....
Hopefully you were powering ALL interconnected equipment from the SAME receptacle. People can destroy the input circuit of powered speakers by plugging them into a receptacle at the stage and then powering the mixer from another receptacle... Pro's know to power ALL interconnected equipment from the same source, be it a receptacle or a power conditioner to avoid ground bounce damage to equipment. They carry power from the stage back to the mixer on an extension cord. You may have had a static discharge that blew one side of the balanced input of the speaker. The parts are inexpensive, however the labor to get at the amp is usually not fun. I have the dual 10 powered Kustom's and one gets at the POWER amp via removing the speaker after the grille... HOWEVER that is to get at the power amp. The Preamp is probably the failure and it is right at the input plug area and you can get at that by removing the panel with the plugs and power switch and volume control.
I don't have the schematic. Look for shorted RF bypass caps on one side of the balanced input circuit and possibly a damaged input op amp.
Apr 06, 2011 | Kustom KPC10MP 10" Powered Monitor Speaker
Output jack
Have you tried another cable between amp and guitar? Usually the cable goes bad first. Have you tried another amp or possibly tried another guitar on your rig? If this still indicates that your guitar's Standard 1/4" TS Jack is noisy, remove the oval cover over the jack and check the solder joints for the wiring. Follow the wires back to the tone and volume pots and check those solder joints. If everything is secure...Plug in, power up and check for noise while turning the volume pots stop to stop. If the pots make a scratching noise, shut down rig and unplug the guitar. Get a can of spray contact cleaner with a small extension tube (available at electronic shops) to spray in the pots while turning them. (May have to remove pots fom the guitar to get at small openings on side of pot can.) Spray jack and test for noise. Jack STILL
noisy...If you can solder...unwire old jack, remove from guitar, take to electronic shop, match to Standard 1/4" TS Jack, install in guitar, resolder wire connections and test. If you cannot solder...take guitar to
a reputable shop or dealer that does this repair. Good Luck! P.S. The
spray contact cleaner can be used on the amp jack, pots and switches
too...just make sure the amp is unplugged from the power supply before
doing any spraying.
Jul 14, 2010 | B.C. Rich Nt Warlock Electric Guitar
My warlock does not work no sound thru the amp. Is there a fuse somewhere on the guitar?
Try looking for a battery pack in case you have active pickups. Otherwise I'd check the output jack first if your cable is good.
Jun 17, 2010 | B.C. Rich Nt Warlock Electric Guitar
My line 6 spider iii30 30 watt amp works with
There is likely a switch contact on the headphone jack that routes the amp output to the speaker. These jacks on most music stuff are JUNK and the contact may not be closing.
If the spring contact is bent so it won't close you can bend it to contact BUT the springyness usually is gone and the contact will be marginal.
May 10, 2010 | Line 6 Spider Iii 30
Line 6 Spider 2x12 100w combo - Input jack issue
Its a 1/4" mono Panel-Mount Audio Jack
and can be bought at
Radio Shack, Best Buy, Any Music Store
Click Here
Average price about $3.00
Mar 10, 2009 | Music
Kustom KPC10MP 10" Powered Monitor Speaker Logo
174 people viewed this question
Top Kustom Music Experts
Torashi
Level 1 Expert
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Kustom Music Expert? Answer questions, earn points and help others
