Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Why dont have heating - Reddy Heater-170,000 BTU Kerosene Deluxe
    Sergeant:
    Champion:
  • 426 Answers
Check the fule support
Posted on Dec 31, 2010
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
My heat dont get hot
You may need a new thermostat, or heater core is clogged.
Dec 09, 2013 | 2002 Kia Spectra
I am replacing a seco ta 2000 thermostat with a with a Lux 1000. Can this be done and what is the cross refference for the terminals
OK Thanks as follows rh&rc install jumper=R O=O Y=Y G=G B=not used X=common not used on new stat E&W2=W but heres the rub, the new therm dont have emergency heat only function the hook up will operate electric&heatpump at same time during demand.The stat will run a heat pump but is not ideal.If you dont want electric heat at all dont use E
Mar 21, 2010 | Heating & Cooling
I dont know how to programme my invisible heating
If the boiler is working fine for the rest of the house, you may want to check the thermostat for the living room or the water zone valve for the living room, you should call a heating expert to find out why living room is cold.
Dec 05, 2009 | KDS Valiant 6380iPTD-01 Notebook
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
Jaguar x type 2002
dot work @ all or just dont blow heat??? few things..either fuses blown heater core went out or if it works but dont blow heat 90% thermostat
Dec 06, 2008 | 2002 Jaguar X-Type
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Heated seats not working
This is the problem with the thermo stat which is inside the seated is defective you need to get it checked and replace it.................
May 25, 2008 | 1996 Jeep Grand Cherokee
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
20 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
