SOURCE: want to reset Sony VGN-NR160E/s Vaio NB to factory
Just power on your laptop and keep pressing F10 key. You will get one wizard to restore your laptop to factory settings.
iTechGuru
www.itechguru.in
SOURCE: I am selling a sony vaio desktop and want to reset
Just go to the start button, all programs, accessories, and click on the
command prompt. At the c; prompt in the window, type the following:
Format
C:
answer all of the questions with "yes"
This will totally wipe
the hard drive of all info.
If you have the original installation
disks, you may want to give them to the new owners. It will make it
easier to reload the operating system and drivers.,
so basically you should Format the drive, then install an operating system
such as xp, or
windows 7 .... it should install most of the correct drivers. If you
have the original disks that came with the computer, use
those.You may
have to go to the manufactures website to find the exact drivers for the
video and sound cards., but that should pretty much return it to
factory settings. If you are really picky and have the bucks, you can
contact SONY for the original disks.
PLEASE CLICK ON SOME THUMBS
UP FOR THE ADVICE!!!
Testimonial: "Thank you very much. This is a solution to my problem. I learned a lot."
SOURCE: i just reset my sony vaio to factory settings and
try downloading the audio driver and install it. if you are using Sony VAIO PCV-J200 you can download your audio driver here http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVJ200&upd_id=174&os_id=7
try the recovery disk or the recovery option of the sony vaio
which operating system ?
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased.
Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
hope this helps
2-Click the "Help and Support."
3-Select the "Vaio Recovery Wizard" option.
