Question about Samson Resolv Sub88 Subwoofer
My Samson Resolv Sub88 is not producing any sound. The unit turns on fine, and my two active satellite monitors that are wired through it play fine as well. But the subwoofer itself does not make any sound. I am using the same setup as I always have and for some reason it now no longer works like it used to. What may be wrong?
5 Suggested Answers
barbu51
  • 566 Answers
SOURCE: Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Posted on Jun 14, 2010
SOURCE: Samson Resolv 65a monitor repair
Its prob a dry solder joint problem.
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html
Posted on Sep 16, 2010
  • 4 Answers
SOURCE: Hi i have a Samson EX500 Subwoofer that makes a
Most likely induced vibration caused solder pad fracturing at one or both large toroidal inductors perpendicular to and close to the heat sink. You should also carefully insert fish paper insulators between these coils and nearby bare metal parts to prevent arcing when the laquer insulation wears (also due to vibration).
Be careful to discharge the 2 main electrolytic capacitors on the power supply circuit board prior to doing any soldering or instant component destruction may result.
Posted on Apr 08, 2011
paulio150
Hi , where is the fuse in my resolve 65a ? i just cant find it.
Posted on May 03, 2014
Why does it play and stop but monitors work fine?
Some subs are switched on and off according to the level of the input signal. The purpose of the switching is to prevent initial "pops" and sub-audible pulsing from damaging the speaker. To the listener, however, it creates the sensation of a sudden loss of hearing followed by restoration.
Jan 21, 2016 | Samson Resolv Sub88 Subwoofer
I need a transformer for my resolv 65a monitor
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
Jan 04, 2015 | Samson Audio Resolv 65a Active Studio...
Samson Resolv 40A,no sound, power light on cables good.
Your best bet is to take them to an authorized repair center. You may also want to talk to Samson directly. Here is their support link-
Support SamsonTech
Mar 19, 2013 | Samson Resolv 40A Monitor Speakers
No sound from samson resolve a6 speaker
Is the input cable okay on othe systems? Is the voltage switch setting correct for yourpart of the world? Is the GND/LIFT switch fully set to one side or the other?
If you are plugged into the 1/4 ich jack- is you plug the correct length? There are 5 different lengths on thses.
It also would not hurt to spray some LPS-1 into the controls and switches and cycle them to clean contacts as well. And into the 1/4 inch jack directing the spray towards the interrupt contacts.
Sep 25, 2012 | Samson Resolv A6 Two Way Active Studio...
Very little output from tweeters Samson Resolv A6
same issue here, my 6 inch woofer is good but the tweeter is not producing sound, i opened the box myself, theres not signal going to my tweeter, how can i check to see if its a wiring or other issues to diagnose myself? heres some pics
Aug 10, 2012 | Audio Players & Recorders
Hi there
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
My tweeters are blown on my Samson Resolve 65a monitors...anyone know what I should get (and where) to replace 'em?
It might tell you on the back of the tweeter what rating they are. I should do a webserch for Samson spares and see what it comes up with.
Feb 02, 2010 | Samson Resolv 65a Main / Stereo Speaker
Samson 65a monitor speaker
If its not to big find a neostick or similar sintetic glue,piece of medicine bandage and black (if speaker is black) mat spray.First put some glue around the rip wait for 10 min and then put the bandage on it.After that again 10 min of waiting and new layer of glue on the bandage.Let it 24 hours for glue to dry an then respray it.If you can do it from the back side its better and repair is almost invisible.
Feb 29, 2008 | Samson Resolv Sub88 Subwoofer
Jan 14, 2008 | Samson Resolv 65a Main / Stereo Speaker
Sub remote works with two passive satallite monitors but sub has no sound
If sub has two signal outputs and if the monitors are full range (passive crosover built in), put mixer outputs to the sub and signal outputs of the sub to amps in.If not mixer outputs to th amp and its signal outputs to the sub in.Or you can use main out of the mixer for the monitors and rec out for the sub.Its just few XLR or jack cables extra.Just make sure that the mixer,sub and the amp are on the same power phase otherwise you'll have brrrrrrrrrrr on the speakers
Apr 07, 2007 | Samson Resolv Sub88 Subwoofer
Samson Resolv Sub88 Subwoofer Logo
217 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
