Question about Dishwashers
Replaced control module on Bosch dishwasher SHE46C, now have an error 6 code. Thoughts???
SOURCE: Bosch builtin 60cm SGV4313 dishwasher
many thanks however intend purchasing new machine
Posted on Sep 15, 2008
  • 338 Answers
SOURCE: Bosch dishwasher will not cycle. Water in base
does it do anything? if not you may have water in the bottom tray.
Posted on Dec 23, 2008
  • 109 Answers
SOURCE: What is error code 2H
doesnt sound like an error code it sounds like its the delayed start feature, not sure that bosch ever used error codes
Posted on Jul 07, 2009
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher, model SHE46C, will not start.
Hi D. McKinney and welcome to Fixya. The problem could be a a simple one like a poor connection at the dishwasher junction box. Based on your discription that's what I'd suspect. Having said that I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Posted on May 14, 2010
SOURCE: I have a bosch dishwash e15 check water
I found this solution on elsewhere on fixya. it relates to a little float switch designed to detect water leaks I think. 1. turn off power and water 2. tilt back machine about 45% (have towels ready to soak up any spill off 3. when all the water has emptied, right machine and retry. if the problem keeps reoccurring, you may have a genuine water leak. I had to try a few times but this worked for me and saved me at least 4 days of hand washing over a long weekend. good luck
Posted on Oct 27, 2011
Dishwasher goes through cycle but when finished it is cold and code E..09 appears
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
Bosch SHU3300 won't run
check your control module.
Thanks
Sergio
Mar 03, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Started with E01 and E25
The E01 fault code means that the dishwasher has suffered a power module failure.
The programming of replacement power modules E01 up until E05 has been locked down by Bosch so in the event of an error code of this type it's recommended that you contact a Bosch approved dishwasher engineer.
Apr 12, 2015 | Bosch Dishwashers
Replaced the control board in Bosch Dish Washer SHE44C and the cycle times are reversed???
I think this board requires coding to your particular model?? your dishwasher has four selection button and a delay start, whereas the module has five selections and delay as it is used in several different modesl. The coding info should have been in the box with the part and may need to be carried out directly on the module with the fascia panel removed. If you post the part number of the module I will see if I can get you the coding information..
Mar 01, 2013 | Bosch Dishwashers
Bosch shu5316uc filling fault
Test the water inlet electro valves.
May 26, 2017 | Bosch SHU5316UC Dishwasher
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
Jul 07, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher Problem
if you remove the front panel (the 6 torx screws) and the facia panel you can access the control module. remove the module and open it up to see if you have a burn mark from the solder melting. if you do then you know to replace the control module
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
May 27, 2008 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch Dishwasher stuck in "Scrub Cycle"
The Control module on our SHU43 blew this morning and when I took it apart to get the module out, I discovered why two of the Cycle selections no longer worked..... the little plastic lever that pushed the switch behind the fascia button - had broken off. You may have the same issue. It's not a cheap fix though as a new module is gonna cost me $175.
Mar 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
