Question about Kenmore Dishwashers
Wash cycle repeats over and over - Kenmore Dishwashers
The wash cycle take a very long time. It repeats cycles. It's balanced, cleaned and the drain pipe is set correctly.
Verify the door switches are activating correctly. If it senses the cycles are interrupted, they could be repeating. See if you have any codes. Check your codes in the manual. Your manual will also instruct you how to check for codes. It is very simple.
Feb 13, 2016 | Samsung 4.2 Cu Ft Capacity White Front...
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
F&P Washing Machine. WL80T65DW1. Washing cycle doesn't end...
Hello Tim, This is a frustrating issue on the F/P washer. You will need to replace the control board in order to solve this problem.
Apr 09, 2014 | Fisher and Paykel Washing Machines
Cycle stuck on 23 minutes and keep repeating cycle
If you do a Spin Only cycle with that wash load will the machine Spin up?
If not any error code?
Does the wash Tub bang around with a Spin Only cycle?
Do you want to DIY the fix or call in a repair service?
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Repeats cycles
this sounds like you have a bad timer. you can get a new one and quite often you can find a place where they sell rebuilt timers for quite a bit less.
Nov 12, 2009 | Washing Machines
NEW DISHWASHER REPEATS THE WASH CYCLE FOR OVER AN HOUR 7 HALF
Dear Customer
please perform the follownig checks
please rate this,thank u.
Dec 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
WASHING MACHINE NOT SPINNING AT END OF CYCLE AND SOMETIMES REPEATS THE CYCLE.
check the turbine blades, maybe the wer'e loosen up. Try to refit that one.ok??
Jan 29, 2008 | Washing Machines
Dishwashers Logo
22 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
