Question about Spinmaster Air Hogs Helix 360 Helicopter
The little flight stabelizer thingy above the propeller on my helix 360 is not working properly. i can hold it in my fingers and while the propellers are spinning i can see the stabelizer is tipping forward and to the side causing the helicopter to constantly move forward and to the right untill it crashes into something
    Problem Solver:
  • 12 Answers
Check for damage to any of the linkage. You may also remove the tiny pin on the stabilizer and take it off. use a nail file or dremel tool to round the edges... giving it a more aerodynamic shape, and you a chance to make it balanced. After you do this, wrap each tip with a small piece of clear tape. This mod is good for any of the "square" AirHog balance bars.... it gives you more response and faster movement in all directions. ~VLAD~
Posted on Feb 21, 2011
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
How do you replace the propeller on the Air Hogs Sky Stunt, Blue?
To replace the Propeller on an Air Hogs Sky Stunt plane (I got this from their customer server number):
1.) Hold the propeller and turn the nose (at the grey plastic edge, not the rubber) counter clockwise (aka left) until the nose unscrews.
2.) Slid off the OLD propeller.
3.) Slid on the NEW propeller (You will notice there are slots on the propeller mount), need to line up the propeller with those slots.
4.) While holding NEW propeller, screw the nose back on (similar to step # 1) clockwise (aka right).
Hope this helps someone else.
Mar 15, 2013 | Toys
How to fix top propeller of the helix 360. It keeps flying to the right
The top is a balance bar. Assuming it's still intact and the metal pieces are there, you can round the edges with a file and cover the tips with a small piece of clear tape to give it more of an aerodynamic shape. The factory "square" shape actually makes the heli move around slower. This will also give you more movement in all directions... more response. ~VLAD~
Feb 07, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
My Spinmaster Air Hogs Helix 360 4-Channel R/C Helicopter leans and falls to the left as i am tryin to lift it off. i tried the 'trim' but that doesnt solve it.
yes, this little heli does do that. it's likely due to balance and the the transmitter not remembering your trim settings after power off, but it's made that way. You have to steer it up, adjust the trim, land it.. and then it should rise better. You can try adding weight to the other side with a piece of clay to see if it solves the problem. If so, you can add metal or electrical tape to the landing gear on one side. ~VLAD~
Jan 22, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
MY CESSNA IS NOT TAKING OFF. IT ALWAYS GOES TO HIT THE GROUND, I SPENT A LOT OF MONEY AND NERVER SUCCEDED WHEN TRY TO FLY. COULD IT BE A PROPELLER PROBLEM?
Check the flight controls. Does the elevator works? if it does. then problem is on thrust. check the propeller speed, does it have enough power? Don't forget to check on the powerplant (battery or engine). But judging from your story, it is the flight control problem. cheers.
Oct 24, 2010 | RC Cessna 747 Airplane 4 Channel Electric...
Hi my apache bottom wings are good but top wings dont spin they just sit there they were fine the first flight untill i crash it
Please check the connection of the axle of the upper propeller. Turn the heli upside down and spin the upper propeller manually, try to see if the gear turns if not there is a loose connection. You will find 2 small screws near the gear, unscrew one of them and push the axle then back in place, tighten the loosened screws. Turn the upper proppeller manualy, a few turns will do ansd see if the gear turns simultaneously with the propeller. If it still does not turn, apply a permanent glue to the gear and the axle. This will sure have your heli on flight.
Gerry.
Dec 29, 2009 | Apache Colco Ah 64 Longbow R/C Helicopter
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
Why wont the self propelled brush on the hoover wind tunnel work. large belt is ok. the small belt looks 0k.
no don't do that,have a little patience.check where the self propelled assembly is and see if anything got in there,something might be loose and the teeth are meeting each other.thats a good vavuum.i have 2 but their not self propelled.try taking the belt off the self propelled machanisn and try it again.if it works then something is keeping the propelled machanism from working.dig a little deeper,what do you have to lose?
Mar 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Spinmaster Air Hogs Helix 360 Helicopter Logo
265 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Terry
Terry
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
