Question about RCA RT2360 System
RCA RT2770 receiver won't turn on
My RCA RT2770 receiver won't turn on when I press the power button something just clicks and then it say welcome on the front panel for like a nano sec then turns itself back off. It's a shame that this is doing this It has been a good system now for about 8 months. Is there anything I can do or something that you can help me do to fix it
  • 1 more comment
  • eddiea Aug 14, 2008
    My RT2770 turns on about half the time. If I unplug it and wait for several minutes it may come back on. What should I do?
  • Anonymous Oct 23, 2008
    Same problem here, I am awaiting word back from RCA to offer up a solution to this matter
  • zachbrown817 May 26, 2009
    My RCA RT2770 will only stay on for a second befor it turns off agane. The system worked fine for almost six months and I would like to get it to work agane
It is a high power switch to get it fixed it will cost about 100 $
Posted on Oct 20, 2008
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
Receiver is stuck on welcome screen...can this be fixed?
Yes. It can be repaired. You may have an amplifier or microprocessor(computer inside your RCA) bad. Please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Aug 30, 2015 | RCA RT2770 Theater System
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
RCA RT2770: Problem: I power the unit on, it shows the "WELCOME" text, and get stuck there. No volume control, no input selection control, no sound, nothing. Checked internal fuses/boards for anything...
Yea,I hate to tell you this but this unit does this to alot of people.Mine did this I called,and they said send it in,and they would fix,I got it back after a little over a month,pluged in the fixed one,and it worked for a short time,and started doing the same thing.My unit is 10 months old,and has been broke or in their possesion for about 3 months.I wouldnt recomend buynig another one!!!!
Aug 03, 2010 | RCA RT2770 Theater System
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
RCA RT2870 home theater system 'welcome' screen
Well, I just returned the unit. RCA replied with the following solution:
Let the unit sit with the AC power cord out of the wall for a couple of
hours. Then hit the power button 10-15 times (with the AC power cord still
out of the wall socket!) and then try again.
Oct 02, 2009 | RCA RT2870 Theater System
Rt2770 home theater receiver rca. Hp In?
Mine does the exact same thing. If I pick up the front end of the unit and slam it down on a hard surface, it then displays HP out and sound comes out!! Freaking retarded. I wish I knew what was wrong with it! I asked RCA and of course they never responded. What a joke!
Mar 10, 2009 | RCA Audio Players & Recorders
RCA RT2360 System Logo
1,264 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
