Question about Canon Rebel XT / EOS 350D Digital Camera
It seems that the lowest setting for aperature I can get, regardless if using manual or Av setting is "4". Why is that??? I have tried with both the 55mm and the 300mm lens. On my old SLR camera, I could go down to a 1.8 aperature, and I would like to have access to that again!! What do I need to do??
    Brigadier General:
  • 11,967 Answers
Were these same lenses the ones you used on the old SLR? An aperture setting can't go lower than the lowest aperture of the lens itself.
Posted on Dec 31, 2010
My A1 only works when the lens is off the "A" position. Manually setting the apperture it works fine, otherwise it displays a bunch of EEEEEEEEEs....
The AE-1 requires, that when the camera's shutter speed dial is set on A or Auto, that the lense must be set on the highest aperature (22, 32, whatever that lense has). In all other settings you can move around however you'd like.
Aug 14, 2011 | Canon EOS-AE-1 35mm SLR Camera
I have a code fEE. I can't shoot. What's up?
Usually means that you have a lens with the aperature in the wrong setting for use on an auto aperature camera. Look at the lens and move the aperature setting to the red marking.
Don't feel bad, this one got me for about a half a day two different times the first time I put on my new 50mm f1.8 lens. Great lens, but I'd never had an "old style" lens before.
Just for reference, if you put an old manual lens on your D80, it will show F-- in the aperature display and won't take pictures except in "M".
Sep 01, 2009 | Nikon D80 Digital Camera with 18-135mm...
Cannot take indoor photos without flash
Just as "Wrestling" explained, your camera is operating properly. There simply isn't enough light in the scene that you are trying to photograph. If you're new to photography, it's sometimes hard to remember that the human brain/eye combination is an incredible thing, and no camera can compete with a human being.
What I mean is, there is enough light in your room for your eyes to see detail, but not enough for your camera to 'see' the detail without additional light from your flash. However, there are a couple things you can try.
1. Raise the ISO setting on your camera (check your manual, it's easy). Turn the camera on, press and hold the ISO button (left top of camera) and rotate the main command dial (back of camera, upper left corner). Rotate left or right to lover or raise the ISO number. Watch in the top information panel as the ISO numbers change. Higher ISO numbers mean the camera is more sensative to light; you can take pictures when there is less light available. HOWEVER, there is a trade-off. The higher your ISO number, the more noise/grain your image will have. I think the ISO of the D200 is acceptable for enlargements (8x10's) up to about ISO 640 or 800. I'm very picky, you might find higher ISO settings work fine for your needs, especially if you are not making larger prints. Experiment! remember to change your ISO back to a lower setting when you're done with your low light pictures.
2. Take your camera off the fully automatic "P" mode (where the camera makes all the decisions), and change your shutter speed to a slower speed. The slower shutter speed lets more light into the camera, because the 'eye' (the shutter) is open longer. (Use the "S" mode where you set the shutter speed and the camera selects an appropriate aperature). HOWEVER, there is a trade-off again. The slower your shutter speed the more likely you are to have blurred pictures; your subject will move or your camera will shake. If you're taking pictures of a stationary object or an adult, you can tell the person to sit very still and experiment! As for reducing camera shake, first and foremost, learn to hold the camera properly. I can't stress this enough...it's the biggest reason for blurred photos that I see. learn/practice squeezing the shutter realease, not stabbing it. Then, invest in a lens with the Vibration Reduction feature.
3. Take your camera off of the fully automatic "P" mode and change your aperature. (If you like, you can use the "A" mode where you set the aperature and the camera selects the shutter speed for you). The aperature is how wide open the shutter "eye" opens with each picture. Think of your own eye. In bright sunlight, your pupils close down to small openings, as there is a lot of light available. If you are in a dark room, your pupils open as wide as possible to let as much light into your eye as possible. That's the same way a camera works. So, if you are in a darker room, you need to let more light into the camera...that means a larger aperature. The tricky part to remember is that the LARGEST aperature has the smallest number. That means a 3.5 aperature is a larger opening than an aperature of 16. HOWEVER, once again there is a trade-off, as a larger aperature means you have a smaller depth-of-field; depth of field means the area of your picture that is in focus. I'm sure you've seen landscape photos, where every detail is in sharp focus, the far away mountains and clouds, as well as small rocks and grass or a steam in the forground. That is created by a small aperature with a wide/deep depth of field. Then think of a portrait in a magazine or taken by a studio, where the person is in focus, but the background fades off into a pleasing blur. That's done with a large aperature and a narrow/shallow depth of field.
NOTE: The widest aperature available is determined by your lens, so you can't use all the aperature settings with every lens. Your camera knows this and will only adjust to whatever your lens has available. That's why you might have different settings available with different lenses. Experiment!!
OK, sorry if that was long-winded, but the D-200 is a great camera, yours is operating properly, and I want you to enjoy using it!
Jan 01, 2009 | Nikon D200 Body Only Digital Camera
My photos are coming out slightly grainy in low light. Have played around with ISO and aperture etc but no luck. All modes have the same problem. Camera= canon powershot S5 I5
When you use auto mode on most point and shoot digital cameras ( which includes the F717) the camera software gets to choose aperature, shutter speed, and ISO setting. When the ISO setting is used at the faster ISOs, the images get digital 'noisy' very quickly. There is a much higher noise level in consumer digicams at the higher ISOs, because the sensor chip is much smaller than in the digital SLRs. F2.0 suggests yoiu are shooting at the maximum aperature of your lens and that the light is pretty dim.
If you learn to use your camera in the Av ( aperature preferred) mode at ISOs of 50 or 100, most of the noise you are describing will disappear. The camera should take very nice images at ISOs less than 200.
Consult your manual on aperature preferred or manul setting of the ISO speed
Nov 20, 2008 | Canon Cameras
Nikon NEWBIE
put simply the ISO number is how sensitive the film is to light, the higher the number the more sensitive the film. The ISO on the camera sets the exposure system to give the proper exposure for that film (the f/n80 usually sets the ISO automaticly). Also the higher the ISO the more grainy the picture, I would recommend using ISO 200 film for the pictures you describe. I would set the camera to the P setting it is a good all-around setting.
Nov 18, 2008 | Nikon F80 35mm SLR Camera
My Nikon N75 has F-- on the digital screen
Set the smallest aperture (largest Fnumber) and lock the ring. If the aperture ring doesn't have a lock, you have to switch to manual mode (M on the mode dial).
Sep 16, 2008 | Nikon N75 35mm SLR Camera
External Flash
The aperature error is due to the fact that the lens in not a constant aperature design. The settings on the LCD are assuming you are at full wide angle setting. As this lens moves towards telephoto, the aperature changes about 2/3 of an f-stop due to the mechanical movement of the lens elements. So a manual setting of f4.0 at full telephoto will be more llike f5.0 in reality. It is too bad Epson could not make the mechanical aperature adjust to compensate, but every nice feature costs something. I have not had any issue with the shutter speed changing. One guess is that the camera has shutter speed/aperature combinations that it can't achieve due to mechanical limitations, so it chooses the available combination. Another is that it wasn't in manual mode, but rather aperature priority mode and the final adjustments changed the speed.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Aperture priority only in manual mode?
Yes. You pick the apature (the 3000 keeps it aorund the setting you pick) and then it automaticly adjusts the speed for you.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
