Question about Barrecrafters Hook Kit Sierra Ski Snowboard Rack Sx11
I have the Barrecrafters Sierra sx-11 ski and snowboard rack. I purchased a 2006 lexus gs300 and would like to use the rack on this vehicle. I can't find any information on which speciality hook kit I need to purchase for it to work on my 2006 lexus gs300?
3 Suggested Answers
SOURCE: Need instructions for Barrecrafters ski rack
We figured this one out today, after pounding, twisting, sliding, gerunding, etc.
It will not slide backward (as a safety mechanism, of course) unless your latches (the ones that connect / clamp onto the car) are completely loose. That means, that looking at the rack from the end, you'll see this oblong deal that you'll use to tighten the rack to a car. As you turn it clockwise the rack will tighten, right?
Ok. Just make sure that that guy is as loose as he gets, and your piece will slide back just fine.
Posted on Jun 07, 2009
rockmeister
  • 2047 Answers
SOURCE: I have a Barrecrafters Sierra
Hello there, getting replacement keys for your ski rack is possible. Usually to get replacement keys all you have to do is visit your local distributor. Apparently the keys can be re-ordered from the manufacturers although the name of the manufacturers have been changed to proline products. here is the web address http://www.prolineracks.com maybe an order can be placed from there. Or you could get more information from calling their customer service and locating the nearest distributor to your location.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Aug 07, 2011
What model car does this fit?
if you already know that data no longer available then why U ask .
Feb 20, 2015 | Thule Winter Sports
Barrecrafter ski rack lost key
Lock Smith can do a Tap and File (Insert a Blank and rotate it and File to get the lands and grooves to get it done (Time Consuming) and Cost Extra Money
Try a Different Locksmith
Jan 25, 2014 | Winter Sports
The locks work fine when there's no gear loaded, but when i put my boards onto the rack the locks won't turn. any suggestions?
sounds like a pressure issue ( binding problem ) --- when you go to lock the locks ( with the skis and/or snowboard on rack ) try and push down hard on the rack while you turn the locks,, this might get the pressure off enough to allow the lock cams to pass. if this does not work then the next thing to do is to file down and modify the lock cams so they turn easier without binding. if you do not have the tools to do this modification then you can always go down to your local locksmith shop ( with the skis/snowboard on the rack ) and have them do the modifications -- the shop will only charge you around 10 to 15 dollars for this service.
I hope this helps,
c...
Jan 25, 2011 | Yakima Fat Cat 6 Ski and Snowboard Rack
What exact hook kit part # fits my car. Its a 2005 acura TL
Call Proline Products Inc. at 203-265-7535. They can answer that for you and they might have the hook kit in stock.
Jan 15, 2011 | Barrecrafters Hook Kit Sierra Ski...
Bought a barrecrafter car rack off craisglist...i bought it with no keys because the ownr lost them...i need a replacement
look and see if there are any letters and numbers scribed on the face of the lock cylinder, this is the key code-- with this code you should be able to go to your local locksmith and they will be able to cut you a ' key by code ' and it will work. if there is no code on the lock then you can also just take the rack to the lockshop and they will be able to pick and remove the cylinder from the lock and fit a key to it by hand. normal shop rates for making a key in this fasion is about $12-$15 dollars and if you want more than one key - duplicate keys cost about $1.75 to $ 2.50.
(( even if the lock does have numbers on it -- take the rack to the shop with you to make sure the key that they cut by code works before you leave the shop,,, saving you a second trip ))
c...
Jan 05, 2011 | Barrecrafters /sportrack, Sx-12...
I have lost the key to my Barrecrafter ski rack #007 Who should I contact to find a replacement?
Find a dealer in your area, it should have a number on it for them to get you a replacement. OR, most locksmiths should be able to do the job while you wait.
Feb 05, 2010 | Barrecrafters /sportrack, Sx-12...
I need to know were to buy an additional fastners for my barrecrafter box.
Try the local snowboarding shops, or online directly thru Barrecrafter. Also a local Hardware store my have stapping that may help you out. good luck enjoy the snow
Dec 07, 2009 | Barrecrafters Winter Sports
Jan 24, 2009 | Barrecrafters /sportrack, Sx-12...
Barrecrafters Hook Kit  Sierra Ski Snowboard Rack Sx11 Logo
193 people viewed this question
Top Barrecrafters Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you a Barrecrafters Winter Sport Expert? Answer questions, earn points and help others
