Question about Home
I have an older single handle Foremost shower faucet. The handle has no cap to remove to get at a screw to remove handle. Also there is no place visable to insert a hex key to loosen the handle. I am missing something simple but I can't see it. The handle is metal, curving down with a longish knob that screws off to change from gold/bras to chrome. I have found the letters CCF on the cover plate and the numbers 103323.... HELP... frustrated!!!
  • 83 Answers
Try unscrewing the tube behind the handle itself as you turn counter clockwise the handle should come off along with cover tube
Posted on Dec 31, 2010
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
How do you tighten the shower turn on handle?
If it is a lever handle, there is an allen key set screw on the under side of the handle hub. IIf it is a knob handle. remove the plastic cap at the center of handle and tighten the phillips screw.
Jul 16, 2014 | Delta & Single Handle Shower Faucet
CANT FIND HOW TO REMOVE THE HANDLE TO ADJUST OR REMOVE THE SCALD GUARD
1-For a metal lever handle it will have a allen head screw at the base of the lever to remove with a 1/8" allen wrench. If you can not see screw it may have a cap covering it to remove.
2-To remove plastic acrylic caps remove plastic cap to acess screw to remove handle.
Once handle is off remember the location of the dial to adjust it counter clockwise to increase hot water flow. Slide indicator dial back on stem and reposition about a 1/4" turn counter clockwise and recheck for change in temperature.
If you need any more help refer to the link provided for a digram of faucet. Go to parts down load and view faucet parts view. I hope this will be helpful in solving your issue.
http://www.deltafaucet.com/bath/details/T13022.html
Dec 28, 2010 | Delta & Single Handle Shower Faucet
How do you remove the handle from a classic delta single handle tub faucet? I don't see a way to take off the handle itself to replace the cartridge.
On most delta models you pop the cap in the center of the handle. Then there is a screw to remove the handle. If it is old the bonnet can be hard to remove. Be careful, as you don't want to damate the complete faucet behind the wall.
Jul 18, 2010 | Delta & Single Handle Shower Faucet
How do you tighten or remove handle on a danze shower faucet
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
Jul 02, 2010 | Danze & Single Handle Tub And Shower...
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
How do I remove the single faucet handle to replace it.
There is a set screw in the handle, it can either be a hex screw or it can be a philips head screw depending on which faucet you have. If you have a clear decrative handle then there is a cap that you remove and the screw is behind it. Once you remove it you can remove the other trim.
Mar 22, 2009 | Moen & One Handle Tub & Shower Faucet
Home Logo
273 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
