Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush roll belt is broken. The dc-07 has a clutch, How do I replace the belt?
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
geordie rob
  • 7 Answers
SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
Posted on Dec 29, 2008
  • 27 Answers
SOURCE: how do i fit new brushes in dyson dc 07 have the
you have got to open the motor housing that isthe black casing that surounds the motor first then the motor comes out then you can see the brushes thay come out by lifting the copper strip up gently with a screwdriver then you pull it out then put in new ones
Posted on Oct 03, 2009
Testimonial: "Great thanks that's awesome"
  • 5 Answers
SOURCE: Replace dyson 07 animal brush roll assembley
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
Posted on Oct 27, 2009
Vac Belts
  • 701 Answers
SOURCE: the brush doesn't spin anymore, but the belt is
The belt may not be broken but after 3 years the belt will have stretched and it will not turn the brush. You should change the belt every year. Changing the belt is an inexpensive fix. I would try that first and if it doesn't do the trick I would take it to a repair shop. You can get the belt you need here:
Dyson DC07 Replacement Belts
Posted on Nov 07, 2009
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc07
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 09, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
DC 07 brush bar not working
The brush is driven by two belts and a clutch. Your belts on the clutch are stretched. Their are several youtube videos for rebuilding and replacing a DC07 clutch. Just change the blets don't buy a new clutch. A lot cheaper to change belts. You might as well clean everything up while you gave it apart. Have fun.
Jul 07, 2014 | Dyson DC25 All Floors Bagless Upright...
Brush doesn't spin
This model has Brush Control
The Brushbar can be turned off to protect rugs and delicate floors
You've either accidently turned the brushbar off or the belts broken
Apr 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
DC 07 beater bar won't turn when on carpet setting. Filter has been washed.
The belt(s) need to be replaced periodically. If the belt is worn, stretched or broken it will not pick up the way it should. You can get DC07 replacement belts here:
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush doesn't spin anymore, but the belt is not broken. model DC 07; approx three years old
Nov 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oct 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar belt needs replacedon a dyson DC14 animal
Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
Its in the instruction book
Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Were is brush reset button please
I don't believe the Dyson has a reset button. if the brush doesn't turn when the handle is down then you may have a broken belt. there are 2 belts on the vacuum, the one from motor to clutch can be replaced from under the vac. the belt from brush roll to clutch is not available and must be replaced as a clutch ***'y.
J
Jun 13, 2008 | Dyson DC18 all floors Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
15 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
