Question about Whirlpool Duet GHW9150P Front Load Washer
It keeps stopping and then we get a F 02 code
  • Whirlpool Master
  • 8,220 Answers
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Here's the Handy Hippy's guide to HE Bliss
Posted on Dec 30, 2010
Whirlpool duet washer error code f-02
Error F-02 is a slow drain problem. Remove lower front panel. You will see a circular door. Be prepared for a lot of water and junk, maybe keep some old towels ready. Open, clean out, check pump which comes right behind it - see that blades rotate freely; refit carefully. You are done, for the next six months or so, depending on usage.
Click if helped
Apr 14, 2013 | Whirlpool Washing Machines
O2 sensors keep failing and a evap leak code i put new gas cap did not cgehan ssomers11@gmail.com
Are you sure it's 02 sensors? Just because code says 02 sensors doesn't necessarily mean they're bad. Bad 02 sensor code can also indicate bad cat. converter. If 02 sensors read exact same reading before and after converter they will trigger OBC to "sensor fault" - they should be reading 2 different readings. (Pre CAT/POST cat) I'd suggest replacing cat converter before replacing sensors.
Mar 14, 2011 | 1999 Toyota Camry Solara
Po507 could that be the idol air control
did you replace both 02 sensors? 02 sensors and camshaft position sensor do most of the engine timing. A bad vacuum hose will throw the timing off as well.
Sep 21, 2009 | 2002 Mitsubishi Galant
Blades stopped on my 02 cool fan.
I love the 02 Cool rechargeable/battery operated fans and have them running in my home and office daily. However, they do have a limited lifespan. I get about 6-9 months of daily use before the fan motor goes dead and the blades stop turning. However, I'll keep buying them. I live in an area where we frequently lose power and the rechargeable/battery operated feature pays off when it does so on a hot day.
Jun 25, 2009 | Panasonic Dryers
HELP!!! I keep getting an f-02 error code
F-02 is usually the drain pump on Maytag and Whirlpools.
I would take the pump apart- it should have three screws that hold it together. It could be that the pump has something really small like a paperclip stopping the impeller. Once you have the pump apart, you can even (carefully) wire the two electrical prongs on the pump to an old electrical cord, (carefully connecting one wire to each prong) and plug it into the wall to see if it runs.
The drain pump works on 120 volts just like the wall outlet, so if it doesn't spin when you plug it into the wall it needs to be replaced.
Also, there should be a technician sheet inside the machine somewhere which might have some helpful troubleshooting tips.
I wouldn't advise taking the motor apart until you have tried a lot of other things first.
Mar 24, 2009 | Washing Machines
2004 pontiac grand am diagnostic code P0130
it is an 02 sensor code seeing values off from normal perimeters
Aug 20, 2008 | 2004 Pontiac Grand Am
F-02 fault code on indesit we16 washing machine
According to info on a similar site to this, it means motor jammed/tacho faulty or detatched
Mar 23, 2008 | Washing Machines
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
