Question about Procom MN300TBA Heater
We have three individual heaters out of 14 in our apt complex. Purchased June 2009. The pilot light is shorter than usual and when & if the bar flame comes on it is very low flame. Even when it is on #5 or #6...it is still very low flame and minutes later heating unit shuts off. The apts are all in a row. Apts effected is #1, #6 #11. Heaters before/after and around those 3 apts...aren't having any problems.
3 Suggested Answers
  • 126 Answers
SOURCE: Rinnai 556
Tomeboy,
You are asking a lot for a R553 to heat 700 sq ft. with bedrooms that have doors. These heaters are great but they do have some limitations. If you were building new you could put in quiet room to room fans up high on the wall to move the air into other spaces. Since everything is already built you are really stuck. If you had to you could frame in the fans, do all the electrical, sheet rock and paint or just put a smaller Rinnai in the bedroom. 6 of one, half a dozen of the other.Sorry
Posted on Jan 07, 2009
  • 3315 Answers
SOURCE: We have 14 ProCom heaters,
the pilots should be clean ,they should be playing on the thermocouple if this is so then it could be new thermocouples if it was a pressure problem nothing would work , as it 1 , 6, 9 ,11, it could just be dirty pilots hope this helps
Posted on Jan 03, 2011
Outside main 100 amp breaker is tripping but none of the inside breakers, supposedly when dryer and tv on together but not all the time
Am I to assume your dryer is electrical? If so, I'll guarentee it will draw MORE than 14 Amps if heating. Sorry, can't analyze your problem from here.
May 01, 2014 | Cutler Hammer 100 Amp Main Breaker...
Is a 80 gallon hot water heater legal for a 7 apt. building?
You probably need commercial 150gallon gas water heater.
Or three 80 gallon tanks, depending on number of people.
80 gallon residential gas heater is rated for low-demand 6-8 person household.
80 gallon residential electric is rated for low-demand 5 person household
80 gallon is not correct for 14-28 people in 7 apartments
http://waterheatertimer.org/Whatsize2.html
http://waterheatertimer.org/Two-water-heaters.html
Call local plumber, or local code department.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 10, 2013 | Water Heaters
Heater bionaire bch9224-cn no heat
The Bionaire BCH9224-CN is a ceramic space heater, one of apparently 4 related units. The 9224 is the tallest in the family and I also have the shorter BCH9212-CN. They are electric so I have no idea what all this talk about 'gas', 'pilot light' and 'flame' is. My 9224 failed in a way that seems quite common with Bionaire space heaters in general, namely, first the smell of burning electrical insulation, then a snap or pop accompanied by a flash of light out the lower side, and then no more heat. It is possible that the original questioner had this happen but wasn't around to witness it. Now it is possible that the failure is in the electrical control board but in my case (and in fact I'm betting for many or most of the Bionaire failures) it was a wire running to the ceramic heating block (element) that fried at the connection to the ceramic element. I would say it is very unlikely the failures of the Bionaires are in the ceramic heater blocks themselves, and in fact the 9224 and the 9212 (and I assume many or most of the other Bionaires) actually have two ceramic blocks/elements fastened together, one being used for the 750 watt heating and both for the 1500 watt heating. The central wire running to the blocks must support enough current (about 12.5 amps) for both of the blocks, whereas the wires to the individual blocks need half that (about 6.25 amps). In my 9224 unit the weak spot was clearly where the central, common wire was connected to the spade-like connector that was crimped onto the central, common tab of the ceramic block pair. At first I thought I'd just toss the thing but then I opened it up, did the autopsy and repaired it by replacing the 3 wires from the circuit board to the ceramic blocks with 14 gauge wire, and made the connection of the wires to the three soft metal (tin or tin alloy?) tabs of the ceramic blocks by carefully drilling holes in the tabs and bolting eye, crimp-type wire connectors to the tabs using small screws. Oddly enough I opened up the smaller unit (the BCH9212-CN) and it has the same ceramic element pair but no indication of burnt wires.
Jan 08, 2012 | Bionaire Heating & Cooling
We have 14 ProCom heaters, second cold season...we are having trouble keeping some of the pilot light lit and shutting off after several seconds. The gas pressure in the building is 7.5 lbs and the...
Jan 03, 2011 | Procom MN300TBA Heater
The pilot light goes out about every 4 to 5 days. heater purchased in 2009. problem started right away. WATER WORKS sent out a technican three different times. they replaced the gas valve. problem...
I have had this problem with a couple of MOR-FLO AMERICAN gas water heaters. What I would suggest is first make sure that combustion air inlet screen on the bottom of the heater is clean of all lint,animal hair,etc. Also clean the screen around outside of heater base, not every installer uses this screen.
Next check to see how thermocouple is positioned in burner compartment. If it is touching the bottom of heater then try to reposition it so there is a little clearance.
Check height of flue through roof and position relative to other roof structures. With these sealed combustion units I have had problems with the pilot light blowing out due to wind speed and direction. I have fixed this problem a couple of times by raising height of flue pipe one or two feet. I hope this helps you. Thanks
Dec 02, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light gone out on a mynute 14 se ....vokera....there usually is a flame..
press the pilot button and use a long lighter to light the pilot
Oct 13, 2009 | Water Heaters
Engine light comes on and goes off. PO466
drill a hole in the petrol cap so it can vent
Jul 09, 2009 | 2004 Kia Sorento
Burner and pilot run then kick off
if this is electronic ignition you have a dirty flame sensor.
If you have a standing pilot light you should remove, dismantle and clean the pilot assembley.
Makec sure you clean the small gas oriface located inside the pilot assembly.
When you put it back together I would install a thermocoupling. Can be purchased for about $10 -$14 at any hardware store.
Jan 06, 2009 | Heating & Cooling
Whirlpool water heater pilot light does not stay lite
I have a Lowe's Whirlpool water heater. I've experienced the same problems as I've seen described here. My pilot light started going out several times a day. It was not such a big deal, the tank is well insulated so the water would stay warm - I'd just re-light the pilot before going to bed and before going to work. That worked well for about three days, but the problem got progressively worse until it just would not light at all. I replaced the thermocouple with a Honeywell universal thermocouple that I got at Home Depot - that did not solve the problem. I'm very handy, so I decided instead of going through warranty service and having to wait three or four days for replacement parts, I'd buy a new gas valve at Lowes and try that. It cost $54.00 and it worked. By the way, I put the original thermocouple back in and the pilot light stays lit - it was definitely the gas valve and not the thermocouple in my case. It was a real pain to do since I had to drain the tank, but it only took about three hours total. From what I've read, these things last anywhere between six months and two years. That's ridiculous, but at least I have hot water now. If you are reading this because you are considering purchasing a Lowes hot water heater, DON'T!!! I started my search for a replacement gas valve at Home Depot, but they don't stock them. Lowes had 8 on the shelf. That tells you something right there - the water heaters Home Depot stocks don't need to have the gas valves replaced before the tank wears out - there's no demand for the valves so Home Depot doesn't stock them. Lowes probably sells 8 of them a week - all the boxes were shiny and new, not dirty and dusty like some items get when they sit around in home improvement stores.
Nov 11, 2008 | Water Heaters
Pilot light lit but no heat
the pilot's millivolt generator may be at fault.  if you have a meter that is capable of measuring a very small DC voltage, connect it up to the very end of the thermocouple and the copper cappillary. the thermocouple has a welded bead at the very end inside that generates a small DC voltage. Same principle of a J-K thermocouple. Iron constintan  - two dissimiller metals where joined together produce a voltage when heated.  the thermocouple actuates a millivolt electromagnet inside the valve to keep the valve pellet open.  no voltage there it won't actuate the electromagnet.
Sep 24, 2006 | Uniflame 200209 Open Flame Patio Heater
Heating & Cooling Logo
41 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
