Question about Mattel Sing-a-ma-jig Light Blue Singamajig Mattel Singing
Dropped and stopped singing - Mattel Sing-a-ma-jig Light Blue Singamajig Mattel Singing
What's causing the following problem with air conditioning and radio?
Well you will have these fancy motors all singing and dancing electronics ,the only ones with the software to sort this out is the dealer iam afraid as electronics it is but what and how ?? ask a IT specialist
Jan 18, 2015 | Cars & Trucks
Slow engine heat up
Have the thermostat replaced and have the water pump checked at the same time .
Feb 13, 2014 | Volkswagen Golf Cars & Trucks
When I hit the breaks, the engine idles rough and makes a funny high-pitched whine.
when you hit the BRAKES, does the voltage drop below 13.3v
(cig lighter is good place to check this)
does this , only moving>
brakes can if fact sing. and is not a problem for stopping.
unless the wear limiters ,are hitting. spring there on the pads that
sing.
the engine running rough if related to brakes, is low main voltage power. use a voltmeter to makes sure power to the EFI system
is above 13.3v running. below is a dead charging system
are battery lugs clean?
Feb 07, 2014 | 1983 Honda Accord
I took the car into the accura dealership and they said it might be the tensioner pulley or something similar
the AC clutch turns , A/C off. so if bearing is bad, you can rule it out
with the A/C on , but that spins the compressor, and if it makes noise too. oop. i drop belts. drop belts (after bills boyd stethoscope check)
i drop belts (almost never) to see what makes noise and what dont.
why not believe the dealer, i bet it used a stethoscope and it did make noises, the tool is sold for $5 at harbor-fright(pun).
i listen to all my accessories before long trips to avoid getting stranded. good bearins purrrrr... bad buzzz. try a good car and practice, and do avoid the fan an belts. running. it takes a steady hand and care to work on moving parts...
my sis, came over, one day, i heard her ford , singing to me
as she drove to our house. i said, it been sing long, yes, about 6 weeks. the steth hit here idler in 2min. and sure it was bad.
here ford the idler pulley is stamping, and a perfect bell.... that sings.
when you take a car to a mech, and he hears the sing
and knows the idler is bad, i will not assume its just one problem.
many cars come in with bad, idler, alt bearing and bad water pump.
all ignored, that is why no promises... he is only human and must find
most problems in a serial fashion, try it and see.....
my last 97 had 10 problems. all ignored.
all very serious. one problem took 25hr labor to fix, spun rod bearing.
Dec 28, 2013 | 1997 Acura CL
Singing dancing Santa won't stop dancing
My neighbor just gave me 1 of these... needed the adapter... 4.5 Volt 800 mA and be sure to get one where you can reverse the polarity if necessary. (polarity is: + ---O---- - ) I had to do some "modifications" to the base as my adapter had an "L" base & wasn't long enough - straight adapter would have been better... Santa wouldn't stop singing/dancing- hmmm. Cleaned the motion sensor lens and then had to cover the modification hole in the base to completely darken the interior of the base. Viola now the motion sensor works... is driving the dog crazy!!
Nov 06, 2012 | Gemmy Life-Sized Animated Santa
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
6i have a 2004 doge ram and when am stop at a light or sing the oil perssure will drop but when i go down the road it is fine what is wrong
i sould install a manual guage on it to get an accurste measure on oil pressure, if its low it may just be a filter if not removal of the oil pan will be necessary for further diagnosis
Aug 22, 2010 | 2004 Dodge Ram 1500
Indian chips for entertech
hi , jus need to know the following
are your mics still not working ?
how much wud u want for that set
regards
+919820226998
www.magicsingindia.com
Jun 15, 2008 | Magic Sing Along Consumer Microphone
Mattel Sing-a-ma-jig Light Blue Singamajig Mattel Singing Logo
23 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
