Question about Carrier Heating & Cooling
Oil leaking around compressor - Carrier Heating & Cooling
  • 2,133 Answers
The system is under gas leak. When no gas, the compressor pumps the oil. It's not safe compressor. Don't run the unit. Call repairman for finding out leak and arrest. Then gas charge after vacuum the system. Helpful?
Posted on Dec 31, 2010
Oil leak around air conditioned compressor
The air conditioner system has oil that flows through it when it is on. This means that the seals in the compressor are bad. This is going to be expensive to repair.
May 01, 2013 | 2005 Nissan Altima
Sanden compressor oil leak
If you have an oil leak in a a/c compressor you have no gas as the oil travels with the gas around the system. If the leak is behind the pulley clutch it is p[ossible to have it replaced and if it is at a fitting have the line replaced You will have to regas the system when done and fit a new receiver dryier as well.A quantity of oil will also have to be added.
Mar 11, 2013 | 2003 Mitsubishi Lancer
What causes a compressor to go bad?
Compressor in your car? refrigerator? home air conditioner? Generally compressors die due to insuffecient lubrication. Automotive compressors die due to the fact that the oil in the system is flowing around in the system with the refrigerant. As the refregerant leaks out the oil leaks out with it. re charging the refregerant starts the cycle over again and if oil is not added the end result will be destruction eventually. Also the automotive compressor workes in the hottest of enviroments is usually not used for half of the year (seals dry out ect) and is subjected to intense vibration which dosen't help. Home compressors usually last almost forever and refrigerator compressors most of the time outlive the box they cool since the are in use all the time.
Jul 11, 2012 | 2003 Nissan Maxima
Air conditioner loss of gas pressure
look around engine at the a/c lines for cracks or if u can see condenser [mounted with radiator for cracks or holes usually a leak has oil around it still even if u find the or leak u have to replace the part vacuum test the system [to remove all moisture]and than add freon also if seal around compressor goes bad causing leak would have to replace compressor lots of tools and or equipment sometimes is needed to repair an a/c leak and ur 84 uses r12 freon hard to get and expensive most likely while fixing good idea to retro fit a/c to r134
May 13, 2012 | 1984 Chevrolet Caprice
I've got a compair 660A air compressor and have oil leaking out of the body of the oil pump cover.
I didn't think this was a pressure lubed machine. Is it leaking around the shaft seal, behind the flywheel? If it's just the oil leak, and the unit runs/sounds fine otherwise, you could put a gasket and seal kit in it.
You can search online for parts, but probably have better luck calling it a LeRoi 660A. Compair bought them years ago, and let the piston compressor business slowly die.
Mar 15, 2011 | Air Tools & Compressors
Red /yellow cloured oil leak around behind front wheel line
if it is yellow it could be the aircon compressor, if it is really red to pink, power steering or automatic transmission leak
Jan 08, 2010 | 1997 Mercedes-Benz E-Class
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My GE refrigerator is leaking cold air at the wires coming out from the back of the refrigerator. The frame around this hole is cold. Is there a leak inside the refrigerator? What can I do to fix this...
refrigerant could leak inside the unit, it could smell bad if the compressor had a burnout
refrigerant carries oil troughout the system and back to the compressor
if the compressor had a burnout, the oil would turn acidic creating an odor if there is a leak
personally I would check what's inside, open a box of baking soda and see if this eliminates the odor
if your fridge quits cooling, you've got a leak
Sep 17, 2009 | Refrigerators
Seem to leak iol around the bottom of the compressor
Hi
Always check with manufacturer, some compressors actually take auto trans oil, but check first.
Aug 13, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
The compressor only reach 50 PSI.
Does the compressor continue to run but not build more pressure? In which case it is an air leak most likely, or does the compressor shut off at 50 PSI? In which case it is mose likely the pressure switch. If it is an air leak you can un-screw the guage and coat with putty or teflon tape and reinstall to clog the leak around the threads..
Jan 26, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Heating & Cooling Logo
138 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
