Question about Cobra 29 LTD CB Radio
New power chip
Replace cobra power chip with RF-C1969 chip
    Guru:
  • 773 Answers
Won't do you any good unless you change the driver too.
Posted on Feb 19, 2009
    Brigadier General:
  • 6,966 Answers
To my knowledge on a Cobra 29 board, replacing TR14 (2SC2029) with a 2SC1969 is supposed to improve/increase the TX power output. Additionally however, L12, 13 & 14 must also be adjusted while the 29 is hooked up to a dummy load/watt meter. Should you wish to try for experimental purposes only:
  • Modulation improvement - adjust VR4 to desired level or cut D11or max talkpower remove TR18 .
  • replace TR14 with 2SC1307 (or 2SC1969).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 06, 2008
Tx light comes on but no transmitt
is mic plugged into radio? put oin another 4 pin cobra mic and see if it still happens.make sure your squelch is wide open and rf gain is also.If you still have the problem it could be several things. Final , main IC, or audio chip.
Jan 27, 2014 | Cobra 29 LTD CB Radio
My cobra 29 lx is saying that my rf gain power failed why is that
you may have burnt the diode that a variable controls or you messed with it and burnt it out.
Jan 21, 2014 | Cobra 29 Lx Full-featured Cb Radio
What are finals
T36- 2sc1969/c1969 Output
T37- 2sc496/C496
T38- 2sc1306
T39- 2sc1973
Feb 22, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
There is no output when transmitting the radio says rf power output fail on the radio check
You can try to replace the final transistor and see if that helps. Do you have receive? Plug an external speaker into the PA and switch the CB to PA and key down. If you hear yourself that eliminates the voice chip. Always make sure you check your SWR and maintain below 1:1.5 no higher than 2. Any further questions of comments let me know.
Mar 01, 2011 | Cobra Radio Communications
I turn on my cobra 29LTD BT and theres is no RF gain nose what so ever. I put a new coax on and still nothing. The RF gain is alll the way up.The RF gain comes and gose.
firstly check your antenna feed (coax) for short with multimetre if this is ok problem might be your audio stage in the radio might need to be replaced hope this helps
Jan 03, 2011 | Cobra 29 LTD CB Radio
Have cobra 29wxnwst radio. Truck sat for 3 months
Turn up the RF gain all the way and leave it.
RF gain is basically how open your receive is. There is really no reason ever to have it down unless you are trying to hear only close stations to you.
If you RF gain is up, your mic pins my be oxidized, or mic bad.
Try a different mic, and or clean the contacts in the connectors.
Sep 18, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Af audio power amp
Just because the chip is warm doesn't mean it's bad, especially if it seems to work fine otherwise. Do however make sure that the device is properly heatsinked, and inspect the work done in the process of any modifications. If for some reason the device is self-oscillating it could do so at a frequency above hearing thereby going unnoticed. That will cause the device to overheat, and also make modulation weak and the RF to splatter out of band. You'll have lots of power on the RF wattmeter, but people can barely hear you if that's the case.
May 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 148 gtl b no recieve
make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Jan 08, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
424 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
