Question about Kitchen Ranges
I have a oven/ceramic cooktop that is just over 3 years old. About 1 1/2 years ago, one of the hotplates stopped regulating temps, if it was 'on' it was 'high'. Since then, one by one, all four have contracted the same problem. When I contacted FP they suggested that the elements would need replacing. This does not make sense to me as they all work (too well) so I was thinking the limiters or a thermostat... advise would be much appreciated Susan
  • wilgas Jul 08, 2008
    It is nobs & I think you have solved my problem..thanks
I need more information. What kind of controls? A knob you turn or computer touch controls? If it is a knob it is most likely the switch is bad. THese cost around $25 each. The control switch controls the heat by pulsing the element on and off . High is constantly on, lowest setting is around 5% on. This is usually an easy repair. THe switches have 4 - 6 wires. 2 marked L 1 and L2 (Usually black and Red) Two terminals marked Load 1 and Load 1 , Maybe a neutral and a pilot light terminal. Do not mix up the L1 and L2. The load terminals (going to burners) really don't matter. They may even be the same color. THe L1 & L2 terminals must be the same on all 4 switches. The switch you get as a replacement may look different from the original. As long as you ordered by model and serial # they will fit.
Posted on Jul 08, 2008
Hotplate and oven temp
There are several possibilities. Make certain your fuse at the main electrical box is correct for a 220VAC line. You do not want to OVER POWER the range. If that is normal, check all cords for insulation and flexibility. Check thermostat controls on the burners and/or oven.
If parts are normal, the only thing you can do is manually set temps lower when using the oven. Glass tops generally stay hot for several minutes after they are turned off. That is Normal, for example, to avoid Glass from fracturing; temperature slowly declines. Lastly; if all is lost, call for a serviceman to check it out, as you do not want a house fire.
Jan 11, 2018 | Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
I am experiencing some problem with the controls on the cooktop. When turning the dial to the desired temp, sometimes the burner comes on, sometimes it does not. Some of the burners only engage when we...
I haven't heard of this problem before. If you do press down and the hotplate starts to work we know that the hotplates are okay. The only thing this could be is an internal problem inside the hotplate controller, possibly with the contacts. The controllers will need replacing.
Mar 04, 2011 | Whirlpool GJC3034 Electric Cooktop
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Scratched cooktop
as far as i know its normal to have an scratched in glass ceramic hob defend how long to use or many times of use.do u think is same usage? its normal defend on usage.
Jun 20, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Gas oven knobs seizing when oven hot
hi my name is mark, yes most manual gas valves can be disassembled and lubed. you will need gas valve grease. remember a little goes a long way and shut off the gas to the unit before disassembly.
Feb 21, 2009 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Oven does not heat up
there is a fuse that controls the oven functions.. try replacing it.. good luck!
Dec 02, 2008 | Frigidaire FGF337EC Stainless Steel Gas...
Kitchen Ranges Logo
107 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
