Question about Canon Office Equipment & Supplies
I have a used canon gp200s copier/fax. there is an error light on next to the fax button and it won't let me copy anything- it always starts in fax mode. any suggestions? Stan
  • Canon Expert
  • 122 Answers
Press the fax switch and see what kind of error it is showing there after a solution can be possible.
Posted on Jan 02, 2011
I can't erase the faxes I already send
Hi There,
While not as popular as they were before the Internet became a principal means of business communication, fax machines are still an essential item in many offices. They are particularly useful on business documents when a signature is needed. Canon makes a number of fax machines that use both ink-jet and laser technology to receive and print documents. Most fax machines store incoming faxes in memory so you can reprint them, but occasionally the memory becomes full resulting in an error message. Your Canon fax machine's memory can be cleared quickly and easily so you can start using it again.
Instructions
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
Nov 27, 2011 | Canon Pixma MX410 All-In-One Printer
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Workio 150 fax - won't go direct to fax always
You change to the defult setting of your copier sold be set on fax. Try this link and download the operating manual. hopefully this will help you.
http://panasonic.net/pcc/support/mfp/
Jul 07, 2011 | Panasonic Workio DP-150PA Copier
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
My printer is a Canon Pixma MX340 it is showing a error Document in ADF Press [ok] but after pressing ok another error reads Close the feeder cover [ok] eject the document
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Sep 04, 2010 | Canon PIXMA MX340 Wireless Office...
Printer does not print automatically. It prints manually
It may need a firmware update, new software, Also check that your drawer sizes are set right. If so you need a canon tech to visit.
Jan 10, 2009 | Canon USA - COPIERS - ImageRUNNER 2010F...
Canon Copier Key Panel Problem
Replace display touch control panel
Deshpande +919420906982
Oct 19, 2008 | Canon imageRUNNER 400S Copier
Jams for Legal Fax only
Change the separation fingers in the fuser units upper heat roll{teflon coated} use only OEM parts. you may need a service call from a tech.
Make sure the exit rollers are clean and are not obstructed. clean with alcohol.
Apr 25, 2008 | Office Equipment & Supplies
Copier is showing warming up but will not start
the fuser unit has ceased to heat...it has a bad heater. the fuser is a hollow metal roller that usually has a powerful light inside to heat the metal. a continuity test can detect
Mar 21, 2007 | Panasonic Workio DP-150PA Copier
old marine
old marine
