Question about Dell Computers & Internet
Will not burn cd or dvds goes to the end and says error
    Sergeant:
    Champion:
  • 217 Answers
There could be so many reasons why this is happening.
Look here first to see if it's any help or guidance.
http://www.acoustica.com/mp3-cd-burner/support/burning-problems.htm
Posted on Dec 30, 2010
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: My LiteOn iHAP422-98 9 IDE
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Posted on Jul 15, 2011
LG HL-DT-ST DVD RAM GSA -H55N ATA dvd drive not detecting any dvds, while the cds are detected very well ????
built in 06 or 07 , it has reached the end of it's life expectancy , and need replaced
Oct 23, 2015 | LG Computers & Internet
DOES NOT BURN CERTAIN TYPE OF DVDS
If it is a cd-rw, as you've indicated above, it will not burn DVD's. The front of the burner will list what it can burn. For instance, my machine says DVD-+RW, which means that it can burn to both + and - DVD's, but it cannot do Dual-Layer (DL) DVD.
Dec 12, 2012 | Acard Technology (CD1TO7T) CD-RW Burner
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Nero express burning problem
There is a big chance that your CD/DVD is defective or your CD writer. Have you tried burning another CD?
Jan 05, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
I cannot burn CDs or DVDs using this drive this has just happened this week, I have restored laptop and brought it back to the factory settings and it still does not work. Media player burn says a error...
As with any CD/DVD drive problem, try a laser lens cleaning disk. Any dust on the lens can cause failure Doing a cleaning is fast and cheap so it's the first thing to try.
Oct 11, 2009 | Computers & Internet
Why would my dvd writer start finalizing?
Try a Better Brand of DVDs. Cheap DVDs sometimes doesn't burn correctly. Get a DVD cleaner and clean your DVD player.
Jan 08, 2009 | Microsoft Windows XP Professional for PC
EXTENSA 4420 DVD-RW WON'T BURN DVDS
This could be a glitch with your burning software. Try removing and reinstalling it, or using a different software. The other possibility is the drive, occassionally with a CD/DVD combo drive the DVD reader or burner will fail, leaving the CD end working.
Jul 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
