Same problem as patrick I have camex 152-a. no menu appears and does not install because it can't find driver when plugged into usb of pc. Inserted disk and all i got was a chineese version of Media Player Classic
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Posted on Jan 25, 2008
  • 758 Answers
SOURCE: Sansa C250 not recognised
You need to update your windows media player to at least 11..there are other drivers that is currently missing on your windows and installing windows media player 11 would get you all the other drivers needed....
Posted on Feb 08, 2008
SOURCE: MP3 PLAYER PROBLEM
log Vol
Posted on Feb 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa scan disk mp3 player
guest - you must have Windows Vista - it's not compatible
tooth -
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Posted on Jul 06, 2008
SOURCE: YP-P2 is not recognized at all as a device from my PC and Laptop!
hi
i got a problem. when i purchace yp-p2 it works normally.but now when i connect it to my pc my usb cable is not working now what i can do now .i cant dounload any songs.can u give me any solution
Posted on Nov 07, 2008
Dwa 140
Next, open device manager (Click Start Menu and type in "Device Manager", right click and run as administrator). Then find your device in the list, and uninstall it. Immediately, unplug the wireless USB from the computer. Now, restart your computer with the USB unplugged. Insert your driver disk and install the driver, when prompted plug the wireless USB back into the computer. Hope this helps.
Jul 01, 2013 | Computers & Internet
I have dell inspiron 1545 laptop with vista. i want to use a dell optical mouse with it but usb device is not recognized message appears when i plug it in usp port/.i have installed both vista and dell...
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
don
Feb 13, 2011 | Computers & Internet
My computer won't recognize my camera when I try to load photos
Two Possibilities:
1) There's no driver installed, or the installation failed. ( A notification will say so when you plug it in ). Be shure the driver is setup properly.
2) The setting on the camera is set to "WebCam" and not "USB Disk"
In the settings menu, (Not the photo menu) on the camera there will be a USB Function option; this sets the camera up to behave like a cardreader and set the plugged in camera as an aditoional disk drive.
The other setting for the USB Function is "Web Cam" or "Digital Camera"; this will set the plugged in camera to behave as a USB Web Camera accessable to tv tuners or other recording or chat software.
To test, open the "My Computer" display of available hard drives, Disc Drives, Floppy Drives, and Memory Card Drives, then plug in the camera into the USB connector. A USB signal sound will alert you and a new drive should appear on the My Computer list, that's the camera.
If you don't get a new drive, then unplug the USB connector and enter the Menu on the camera, look for a USB function menu and set it to Disk drive, or whatever is not Web Cam function.
Note: This is for PC, and not Apple type computers, but I'm shure an Apple computer would be similar.
Cheers.
Richard.
Oct 13, 2009 | Canon Cameras
My USB ports no longer detect devices when plugged in.
Updating, or in some cases reinstalling, the drivers for your computer's USB interface should resolve this issue.
Locate the iPod in Device Manager
  1. Connect iPod to the computer.
  2. Quit iTunes if it launches.
  3. On the Start menu, click Control Panel.
  4. In Control Panel, open Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  5. Double click the Computer Management shortcut.
  6. In the left column, click on Device Manager.
  7. In the right column, click the plus (+) icon next to Universal Serial Bus controllers to expand this selection.
  8. Locate the iPod in this list. In some cases one of the entries will have "iPod" in its name. If no such entries are present, the iPod is most likely represented by "USB Mass Storage Device."
  9. Note: A red "X" appearing next to the iPod's entry in Device Manager indicates this device is disabled. To enable this device, right-click its entry in Device Manager and choose Enable from the shortcut menu.
  10. Update the USB driver
    1. Right-click the iPod's entry in Device Manager and choose Update Driver from the shortcut menu.
    2. In the Hardware Update Wizard that appears, select "Yes, this time only" to allow Windows to connect to the Windows Update Website. Click Next.
    3. Select "Install the software automatically (Recommended)" and click Next. Windows searches for updated drivers and installs any it finds. If Windows is unable to find updated drivers on its own, continue with step #4.
    4. Click Back.
    5. Select "Install from a list or specific location (Advanced)" and click Next.
    6. Select "Search for the best driver in these locations."
    7. Select "Include this location in the search" and type the following in the field below: C:\Windows\INF
  11. Click Next. Windows searches this location for drivers and installs any it finds. If Windows is unable to find updated drivers on its own, you must reinstall the USB drivers as shown below.
  12. Note: During installation, if a message appears stating that the software you are installing "has not passed Windows Logo testing" click Continue Anyway to continue installing the drivers.
  13. Reinstall USB driver
    1. Right-click the iPod's entry in Device Manager and choose Uninstall from the shortcut menu.
    2. In the resulting dialog box, click OK.
    3. In the Device Manager window, right-click Universal Serial Bus controllers and choose Scan for hardware changes from the shortcut menu.
    4. Windows automatically reinstalls the necessary USB drivers and attempt to remount the iPod. Regards...
Apr 06, 2009 | HP Compaq d530 CMT PC Desktop
I need a cam driver
I have a gigaware pc cam 25-152 and I need the driver to install it
Mar 16, 2009 | Radio Shack VGA PC Camera Webcam
How do i transfer pictures to my memory card
Connecting the camera to a PC
1. Turn the PC power on.
2. Turn the camera power on.
3. In any mode other than Voice Recording mode, press
the MENU button.
4. Press the LEFT/ RIGHT button and select the [SETUP]
menu tab.
5. Select the [USB] menu by pressing the UP/ DOWN
button and press the RIGHT button.
6. Use the UP and DOWN buttons to select
[COMPUTER], and then press the OK button.
7. Press the menu button twice and the menu will disappear.
8. Connect the PC and the camera via the USB cable.
- Insert the small plug of the USB cable into the camera USB connection terminal.
- Insert the large connector of the USB cable into the USB port of the PC.
- The plugs must be firmly inserted.
note: driver for a40 must be installed in your computer.
you can get it here.
Jan 09, 2009 | Samsung Digimax A40 Digital Camera
Nexxtech External Floppy Driver Problem
Normally windows will install any driver for a usb floppy drive automatically. If it needs one. I'm surprised that it hasn't just worked by plugging it in as there cheap floppy drives over purchased have all just worked without the need to install drivers on win xp and higher. Remember you won't see the drive appear under my computer until it has a disc inserted in it though.
Jul 17, 2017 | NexxTech USB External Floppy Drive (NEFD2)...
Sigmatel s4
hi there!
you first have to install the driver software for your cell phone...
as in windows Xp it shows MT6225...
after installing the usb drivers when you connect your cell with usb cable on the cell phone a menu will appear...
- Mass Storage
- Com Port
- Camera
you have to select the mass storage option then your cell will show it self as a usb disk in PC... and if you have Memory card then there will be two usb drives appear in your My Computer Window....
you just have to copy paste your files...
Aug 29, 2008 | Handmark Software MobileLists (950142) for...
Mini-cam O'rite
hi,
its a spanish website but it has alot of drivers
http://drivers.softonic.com/seccion/17/Webcams
good luck,
J
Jul 16, 2008 | GE MiniCam Pro HO98756 Webcam
Cant get the camara to work
start from scratch here..plug and play should see that camera on USB port(try more than one if you have them) and then follow the install guides. You MAY need to remove those old install programs, through Add/Remove programs in control panel.
Patrick
Feb 06, 2008 | Microsoft LifeCam VX-1000 Webcam
 Grubhead
Grubhead
