Question about Coby TF-DVD5010 Portable DVD Player with Screen
Do not have remote how do you open it? - Coby TF-DVD5010 Portable DVD Player with Screen
    Problem Solver:
  • 14 Answers
There should be a button on the system that says open so try and look for it and see.
Posted on Dec 31, 2010
Cannot open battery compartment on remote
Either push the finger / thumb indentation down and along remote or release the small catch at one end of the cover using finger nail and lift the cover off with same finger nail
Jan 12, 2016 | Televison & Video
I cannot get the battery compartment open on remote. Samsung UN50jU7100F
Samsung cannot open battery cover Remote Controls ...
www.fixya.com > ... > cannot open battery cover > Remote Controls
Samsung remote controls cannot open battery cover related questions and answers. Ask your Samsung questions. Get free help from remote control experts.
How can I solve if the remote control is not ... - Samsung
www.samsung.com/sa_en/support/skp/faq/239888
Samsung ElectronicsDec 11, 2014 - 1) Open the battery compartment on the back of the remote and ... If you have any digital camera (including a camera phone), you can test any ...
Remote Control Issues - samsung product support network
Jan 12, 2016 | Samsung Televison & Video
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES.
THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY.
YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY).
BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
Dec 29, 2014 | Craftsman Sears Liftmaster Garage Door...
FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH INTELLICODE REMOTE CONTROL SERIES II ELECTRONICS. PROGRAMED REMOTE FOR NEIGHBORS DOOR, WHRN NO LONGER NEEDED THE ACCESS I RE-PROGRAMED TO MY DOOR. NOW BOTH...
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Nov 22, 2010 | Genie Company Genie Intellicode 1Button...
My opener opens both garage door I only want it to open one
You will need to erase both openers out and recode.
Press the learn button on the motor head until the led light goes out on it. Wait for 2 minutes. ----- Press and release the learn button and then press the button on the remote 3 times and try. Genie openers sometimes take multiple times doing this to code in for some reason. For multiple remotes repeat from -----. For the other opener do the same thing but with a different button on the remote, unless you have a 1 button remote then use different remotes for the 2 doors. Thanks BB
Aug 31, 2010 | Genie Company IntelliCode GICT390-1BL...
Remote control unit does not open the door. we
You can try reprogramming the remotes to the opener that is not working. Sometimes they get a brain freeze and drop the codes and reprogramming can fix it. Next to where the wire hangs down will be a colored square button (the learn button) press once and release, you have 30 seconds to try and program a remote, you don't need to do all in the 30 seconds. Press and hold the button on your remote that you want to use until you see the light on the opener blink or hear a click sound from opener, let go of the button. it should now be programmed. If you can't get any of them to work then the logic board is bad.This repair can cost as much as a new opener + install. Sears sells a "remote control conversion kit" it comes with 1 remote and a plug in receiver you attach to your existing opener. 2 wires come off it and hooks up where your wall control hooks up at the openr.It's pretty easy to install. FYI the remote controls are color coordinated meaning the buttons on the remotes have to be the same color or they won't work, so if existing remotes are not the same color as the one in the kit they will most likely have to be replaced. good luck!
Jul 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door is opening when the neighbor open theirs with remot
You say you "setup the remote and the main box but doesn't solve." I think you mean you programmed the unit but I'm not sure. Anyway try holding the smart/learn button in for 10 seconds and this will erase the memory. None of the remotes should work. Now when you are sure the neighbor will not be using their opener, program your remotes. This may be what you did but I'm not sure.
Aug 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener remotes not opening garage door.
You have to sync the remotes to the new code. For older remotes, you can open the remote and match the pin settings.
For newer remotes there's a button that you push in the back of the opener that sets in program mode (for Chamberlain). When you push the remote button, it will acknowledge the remote is programmed.
If this doesn't help, comment back on your particular model and we'll help you with the solution.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Coby TF-DVD5010 Portable DVD Player with Screen Logo
16 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
