Question about Saws
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor even trying to figure out how to change that *#@ blade. It's probably circa late 90's.
  • 376 Answers
Well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Posted on Dec 31, 2010
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
How do you change the blade on a chicago jigsaw #35778
Like most reciprocating saw there would be a screw on the collar. The collar is the piece of metal on the end of the shaft that moves up and down simply loosen this set screw and pull the old blade out.
Mar 22, 2011 | Garden
BOSCH RS15 SAW WILL NOT WORK, DOESN'T TURN ON AT ALL.
Check your power supply if have a supply input to the motor of your saw,check also the fuse...if no problem in your power source/supply you can browse or check this site to get some information or guide on how the saw function
http://www.ereplacementparts.com/bosch-rs15-060164e064-114-reciprocating-saw-parts-c-128_1131_7890.html
Mar 10, 2011 | Bosch RS15 1 1/4 Reciprocating Saw
Manual for bosh pneumatic jigsaw need to rebuild a jigsaw
finally found it. go to "ereplacementparts.com" and on the left side click on Bosch tools. type in the number0607561118 and you can download a parts schematic for this tool. If I have helped you in anyway would you please vote accordingly and thank you.
Feb 11, 2011 | Bosch 7561118 Orbital Action Jig Saw...
I place my bosch bat on the charger knowing it is full dead and nothing happens. The bat is only a few months old and not used that often.
Bosch has has some problems with their batteries. Take that battery back to the supplier or warranty service center if it is still under warranty.
Nov 04, 2009 | Bosch 1646K Factory-Reconditioned 18V...
My 9 month old Bosch 1590 jigsaw will not start??
The problem is the switch, or trigger switch. It may just have saw dust in it or it may be shot. Try blowing the dust out of it with a good blast of compressed air. If you don't have a compressor to do this go to a tire shop. They will help u.
Jun 20, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
Apr 21, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
I have a bosch jigsaw I purchased at auction.I can't figure out how to change the blade
There are two types of "quick release" mechanisms on the new Bosch jigsaws, the twist-top handle found on 1587 models, and the lower-lever found on the 1590's.
The "twist-top" is the black cap on the 1587 at the front of the saw. You must first put the orbiting control ( on the side of the saw ) to position number III. This releases pressure on the blade. Then you lift the black cap, rotate three or more turns counter-clockwise ( as seen from the top ) to release the locking mechanism. If the saw blade is cool, you can carefully remove it with a single one-quarter turn using your fingers. If the blade is still hot from sawing, use a pair of pliers, but be gentle. Hot blades can bend easily and jam.
The 1590 models are quite a bit easier. You still want to put the orbit control to position III to release pressure. But the quick-release is a simple flick of the black switch on the front face of the saw.
I still have my 30 year old Bosch with the screw-in blade holder. It still works and the saw still runs smooth as a sewing machine. If you are doing a lot of production work where you need to change blades frequently, the Bosch 1590 is the clear choice for quality and value. In thirty years of using Bosch tools, I have only had to do normal maintenance and had only one minor failure, which was the blade changing mechanism on the 1587 model. I broke it by tightening too far. SO, if you have a 1587 model, DO NOT OVER TIGHTEN. As it is, this non-warrantee repair only cost $16 bucks and took two days.
It should go without saying, but just to be safe I'll say it anyway... OBVIOUSLY, you should UNPLUG the tool when you are changing blades. Good luck!
Aug 03, 2008 | Computers & Internet
Saws Logo
222 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
