Question about Brother MFC 8300 Laser Printer
Scanning How do I scan from my printer into my computer to save a document? Thank you
    Sergeant:
  • 287 Answers
Here is the MANUAL for download.
I cannot see any reference to scanning, It appears to be a fax with print capability as far as I can see.
refer section 14.2 fro info on printing
You will nee a driver installed to print go HERE to download this
Posted on Jul 08, 2008
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
How do I scan a document? I press scan and it asks me to wait and then nothing happens.
You didn't mention which machine is it for. Either way scanners need software listening on the computer side to accept scanned images.
So assuming that there are no hardware (including cables to PC) problems, you should check that proper driver and application software are installed. Re-installing is a good idea.
Good luck
pls. vote for better service... Thank you
Nov 20, 2010 | Office Equipment & Supplies
How do I scan and save to my computer
Dear Sir,
plz follow this step to solved your problem,
1.
Turn on your all-in-one printer and computer. Check the connections between the two machines.
  • Step 2 Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  • Step 3 Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  • Step 4 Close the printer's document lid slowly so the document does not shift position.
  • Step 5 Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  • Step 6 Push the scan button. You may have to do this on the printer itself or on your computer.
  • Step 7 Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  • Step 8 Edit the image as it appears on your computer if you want to make changes. Your scanning softwaremag-glass_10x10.gif might let you enlarge, resize or otherwise manipulate the final product.
  • Step 9 Accept the scan and save. Return the original document to a safe location.
  • Thanks For Your Time,
    Apr 08, 2010 | HP Photosmart C6280 Printer
    How do i scan documents so i can email them ?
    How to Scan a Document on an All-in-One Printer Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
    1. 1)Turn on your all-in-one printer and computer. Check the connections between the two machines.2)Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.3)Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.4)Close the printer's document lid slowly so the document does not shift position.5)Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.6)Push the scan button. You may have to do this on the printer itself or on your computer.7)Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.8)Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.9)Accept the scan and save. Return the original document to a safe location.10) once the document is scanned and saved you can email it.
    2. This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
    Mar 18, 2010 | HP OfficeJet 7310 All-In-One InkJet...
    How can i use my pixma mp210 printer to tranfer a picture into my pic file on the computer
    Hello my friend,you mean to scan a photo and save it on your folder?
    If yes
    1. You run the application MP Navigator from your dekstop (or from Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.)
    2. When the one-click mode screen has opened, click the Switch Mode button to switch to the navigation mode screen
    3. Point to Scan/Import and click Photos/Documents (Platen).
    4. Place the document face-down on the platen, and select Document Type.
    5. Click Specify... and set the preferences as required.
    6. Click Scan and it should start scanning
      When scanning is completed, the Scan Complete dialog box opens. Select Scan or Exit. Select Scan to scan the next document, or select Exit to end.
      When scanning is completed, the scanned image appears in the Thumbnail List area.
    7. Edit the scanned image as required.
    8. Click Save or Save as PDF file.If you choose just Save and box will appear to specify the destination folder, file name and file type(usually images are .jpeg .jpg ;) ).
    9. And click Save and your done.
    Scanning Photos and Documents
    Jan 15, 2010 | Canon PIXMA® MP210 Printer
    Scanning
    Scanning Photos With the Control Panel Scan menu, you can scan photos to a file, application, or memory card.
    Scan to File 1 Place a photo or photos face down on the scanner glass.
    2 Press Scan to display the Scan menu.
    3 Press �� or �� to select Photo.
    4 Press �� until Scan To is selected.
    5 Press �� or �� to select File.
    6 Press Start.
    The document is scanned and saved based on the Kodak AiO Home Center scan picture settings.
    You can change the folder where you want these saved. Just go to tools in your printer window.
    Hope this helps- Happy scanning!
    Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
    How do i scan documents and save them in word ready for printing? how can i edit the saved documents? how can i enhance the quality of the documents? thank you
    for scanning plz open my computer and open the scanner icon then follow the instructio.
    for editing the scanned document you have to use a OCR software
    Jul 03, 2008 | Office Equipment & Supplies
    HP Officejet & Vista compatability
    Have you tried to use HP SOlution Center when scanning and save the scanned document to .pdf? try this solution.
    Note: HP Director and HP Solution Center has more likely the same settings
    CLICK HERE TO VIEW: DOCUMENT
    Thank you so much.
    adonscott
    Feb 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    Scanning documents
    Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
    Thanks J
    Jan 24, 2008 | Sharp AL-1551 Laser Printer
    Brother MFC 8300 Laser Printer Logo
    52 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
