Question about Kodak EASYSHARE Z1285 Digital Camera
Lens jammed fully extended and screen message Error L03
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 31, 2010
Canon digital camera A480 Lens error message
Probably the zoom is stack with dust. This is very common in this type of cameras.
You can take it apart and test the mobile parts as shown in this videos:
http://www.desmontalo.com/?p=272
http://www.desmontalo.com/?p=268
Apr 28, 2012 | Canon Cameras
When I turn off my CoolPix S6 the lens would close completely. When I turn on my camera the lens is completely open and the screen just says lens cover error.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Mar 24, 2011 | Nikon COOLPIX S6 Digital Camera
I have a sony cyber t70 camera and have an error code E:61:00 come up on screen and i cannot take a pictue please help me .. what solution can i find for this.. venkatesh
Sony claims that the E:61:00 error means "Difficult to adjust focus Inspect the lens block focus reset sensor". In my experience this means that the gears that extend and retract the lens are somehow jammed. This could easily happen if you hit something with the camera with your lens in extended (working) position.
You should try to:
- power off the camera
- place your thumb on the back of the camera and the fingers a few centimeters from the closed lens
- power on the camera, and with your fingers stop the movement of the lens forcing not to fully extend
- when the lens retracts or stops and then continues to extend, let it go
sometimes this would resolve the issue.
You may want to check this site:
http://www.fewin.com/sony/sony.htm
wich has similar trick for a different model from sony, but the error is the same.
Be careful not to force the lens too hard or you may worsen the issue.
Let me know if this helped, good luck
Feb 28, 2011 | Sony Cyber-shot DSC-T70 Digital Camera
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens jams when extending or retracting
This is either due to a cracked internal roller or a cracked/broken internal cam. The lens will have to be sent to Tamron for repair.
Apr 12, 2009 | Tamron 28-300mm f/3.5-6.3 Minolta Mount...
Will not stay on
Will the lens extend when turning on? , can you see any message on the LCD? it is possible there could be a system error or lens error (lens error if jammed all the way in closed position, usually makes the camera shut off right away)
Sep 02, 2008 | Nikon Coolpix L11 Digital Camera
Lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
336 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
