Cartridge head will not move into position for replacement.
    Sergeant:
    Champion:
  • 217 Answers
Which make and model number is it, please?
Posted on Dec 30, 2010
I have forgotten how to move the ink cartridges into a position where they can be changed.
Turn on the printer. Open the top of the printer to expose the ink cartridge compartment. Hit the "Stop" button. This will cause the printer head to move so that one of the two ink cartridges move above the "No Ink" icon. Hit the "Stop" button again. It will move the other ink cartridge above the "No Ink" icon if it needs to be replaced. The printer head will move to the original position to the right.
Aug 29, 2011 | Epson Stylus CX7400 AllinOne InkJet...
How can I make the cartridge holder move so I can put a new cartridge in pls
Hello -- assuming your printer is connected into a PC via USB or some means - open up the software and find the Ink level supply option or replace cartridge option, this will move the printer head into the correct position.
If it's an Epson there is also a small lever that moves between sheets & envelopes , this also moves the printer head.
Last resort is to UN-PLUG while holding the top open , this moves the printer head -- hope that helps - Ray
May 27, 2011 | Office Equipment & Supplies
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i get the cartridge out
Oct 20, 2009 | Epson Stylus C40UX InkJet Printer
Epson printer: print head not moving to replacement position
Click on Epson, then Monitor status then Properties then replacement. A page will come up saying To get carriage into position click O.K. on this page. When you do that the carriage moves into position and you can take out the old cartridges and replace them
Jan 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I need to replace the color ink in my Epson stylus color 740
To force a Cartridge change press and hold down the Paper feed (load eject) button for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Before changing the carts it is recommended that you run the head cleaning utility.
When you have poor print quality and have tried the head cleaning utility it is recommended that you replace the cartridges. Ift the red lights aren't on to indicate the ink is out you need to force the cartridges into a change position. To do this press and hold down the paper feed button (load eject) for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Regardds
Jan 04, 2009 | Epson Stylus Color 740 InkJet Printer
11 people viewed this question
jasbo
jasbo
