Question about Canon PowerShot SD1000 Digital Camera
When I rotate my camera the image won't turn also.
As I said, when I review a picture and I rotate my camera, the image won't turn. I have not dropped and I always keep it in my case, it just all of a suden stopped working. It is really annoying and I don't want to have to send it in to be repaired- my camera is my most prized posession so PLEASE HELP!
    Genius:
  • 1,673 Answers
Check to see if for some reason this feature is dissabled in the set-up menu.
If the menu settings are okay, it is possible that the position sensor or its related circuits have failed.
The camera would need factory level service if there is a failure.
Jerry G.
Posted on Jul 16, 2008
WHEN CAMERA IS TURNED ON THE SCREEN WILL SHOW PAST PICTURES FINE BUT WHEN THE SELECTOR SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO THE MOVIE MODE THE DISPLAY SCREEN IS BLACK WITH LIKE PURPLISH LINES...
From your description, it sounds to me like the image sensor within the camera went bad.
This can happen from a few things:
  • Camera dropped
  • Moisture
  • Rattling around in a bag or suitcase
  • Knocking into things while in the pocket
  • Leaving it powered on in the pocket
  • Prolonged exposure to bright lights
Try taking a picture while the camera is in picture mode even if you can't see what it is of, then either review the pictures to see if what you just took shows up without issues or transfer it to your computer.
If you can see a picture afterwards when reviewing your images, then it sounds like the firmware may have gotten corrupted. In this case, you should update the cameras firmware using this LINK.
If you cannot see the image you just took, or it has those same purple lines, then it is a hardware problem and can only be fixed by replacing the camera or by sending it in for repair.
Even if you cannot see the image you just took, I would suggest going ahead with the firmware update to see if it works.
Mar 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
When i turn on my camera the monitor remains black and does not show anything that it is aimed at.If I try to take a picture it will take but shows up black on review. Although when I switch it to review...
It is ccd imager chip failure in your Canon A85 camera and ccd imager chip willbe replace to get live view to take pictures.
Canon offers free of cost repair for A85 model for same problem. Click Canon CCD Imager Advisory for details and check your camera model number in that list.
Thanks.
Oct 02, 2009 | Canon PowerShot A85 Digital Camera
Memory Card claims ''no image'' and LCD black and wont take pics
first reformat memory card to FAT file system with computer, then reformat it with camera. this usually is the solution
Aug 10, 2009 | Canon PowerShot A590 IS Digital Camera
Similar problems as other readers. camera turns on but no real time image on LCD screen. LCD contiues to show settings i.e. full auto mode etc. But I can view pictures already taken. Thanks
The XTi and prior EOS models have not capability to see the live image to be shoot on the screen. Only the image after taken can see on the screen. Other images also using the view mode.
If you can't review the images, eve if the display is turned off, just after they are taken, maybe the "Review time" is set to "off". Go to settings, 3th tab, Review time and set the desired setting.
Aug 03, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Pictures are turned sideways
In the setup menu of your camera there is an option to rotate the images automatically, or not to. Just select the option which matches your preference.
Mar 14, 2009 | Canon PowerShot A640 Digital Camera
Can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
Jan 12, 2009 | Nikon D80 Digital Camera with 18-135mm...
Review isn't working
This is not a problem. This is a function that shows you the "burn" area at the photo. If you wishes to drop it just rotate the command dial at rear of the camera. You can change the option by changing the menu as shown at page 75 in the manual.
Guy
Sep 23, 2008 | Nikon D40x Digital Camera
Rotated image
The auto-rotate sensor is probably faulty. Believe it's located near the base of the A95's swivel LCD, and goes bad with time from the repeated opening and closing of the LCD. But it's really not worth the effort to try to fix, as most good free photo editing software includes a photo rotate function if desired. The freeware Irfanview is an example (www.irfanview.com).
If you can live without Auto Rotate (I never use it), turn on your camera and press the menu button. Then select the second "Tools" tab. Then look down through the Tools list for the "Auto Rotate On/Off" selection. Select OFF.
Apr 22, 2008 | Canon PowerShot A95 Digital Camera
LCD won't work in shoot mode, but work in playback mode
It's unusual that you can review pictures, but not see the menu. Take a picture with the camera. If this picture shows up black, then it's probably be a defective CCD imager. If so, Canon will fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Nov 01, 2007 | Canon PowerShot A80 Digital Camera
Pictures rotated when reviewed on camera
The full manual can be downloaded at
http://www.canon.ca/english/index-customersupport.asp?pid=296
There is an option in the menu that allows you to rotate images.
However here are the instructions:
Oct 26, 2007 | Canon PowerShot A95 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
