Question about Frigidaire GLEQ2152ES Electric Dryer
Model LEQ2152ES0 power turns on an timer runs okay. Drum does not rotate and there is no heat. Dryer is only two yrs old purchased at Lowes.
  • 2 more comments
  • Anonymous Jul 10, 2008
    I have A Friidaire Gallery GLER642AS3 electric dryer. When I turn the start switch, the console hums, the light is on inside, but the drum does not spin.
    Could it be the timer is bad, or maybe a fuse?
  • vsalmiery Jul 21, 2008
    replace the heating element and thermal limiter
    when i turn the dryer on i have no heat. i have replaced the heating element, the thermal limiter. I've metered the thermostat. I've double checked the voltage (240) and blown out the motor with compressed air
  • Anonymous Jul 28, 2008
    looking
    Problem Solver:
  • 7 Answers
Check the drive belt is on the pulleys
Posted on Jul 20, 2008
Timer won't stop after cycle finished.
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
May 20, 2015 | Dryers
Frigidaire front loading dryer model LEQ2152ES0 I am looking to purchase a used one, the owner has all paperwork and such, says the drum does not turn, sounds like it trys to but does not. he thinks i
Hey friend, thanks for the post!
If the drum is not turning on a Frigidaire dryer it could be a potential problem with the belt, motor, or control panel. The best thing to have done would be to have a professional come out and properly diagnose the appliance. Hopefully this is helpful. -Matt
Sep 23, 2014 | Dryers
My LG Dryer still runs when it is off and when I turn it on it says to check filter
Sep 23, 2014 | LG DLEX3875V Dryer
Fisher Paykel dryer won't shut off. Dial not moving. Would this be the timer, sensor, or soething else?
Sep 21, 2014 | Dryers
How to fix aFisher & paykel dryer coils are on when dryer is off?
Aug 22, 2014 | Dryers
Dryer works but when time is up it keeps running (cold air)
Aug 13, 2014 | Kenmore Dryers
Dryer not heating
usually when the dryer is not heating is because the heating element has break. you can purchase a heating element kit with insulators at a parts appliance store.requires taking the dryer apart and removing the drum. the heating element is behind the drum. if your handy you should have no problem. good luck!
Jul 25, 2010 | Roper REX4634KQ Electric Dryer
Drum rotates and only occasional heat
The problem is the dryer coils are failing. They tend to fail as they heat up. These are inexpensive and easy to replace.
There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer timer still runs after auto-cycle is complete.
can you just leave the door open when not in use???????
Mar 30, 2009 | Kenmore Dryers
Whirlpool dryer won't heat
Ended up replacing the solenoids and the burner ignited, flame stayed on. Problem appears to be solved. Thanks for your help and posting.
Jan 03, 2009 | Whirlpool LGR7646E Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
274 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
